low gearing 12-speed Ultegra Di2
A gigantic catch-all for Randonneuring (Audax), Bike-packing (Touring), and Commuting with or without E-bikes!
prokyon
by prokyon
Hello, what are some options to low-gear Ultegra Di2? I want somethig like 30-40 as the lowest gear, so 0.75 gear ratio. On 11-speed Ultegra, I can add an Absolute Black front chainring or Rotor crankset with 30T front chainring and then use RoadLink to run an 11-40 MTB cassette in the back, giving me 30-40 as the lowest gear. Use case is bike packing in the Swiss Alps: I ran 34-40 last time and was grinding up Stelvio at 55rpm towards the end... so need to go lower on a different 12-speed bike this time.
I found this gem https://rotoramerica.com/products/12-sp ... 9049789519 which would allow running a standard compact crankset for 34-46 gear ratio as the lowest, but I'm not sure if RoadLink or GoatLink will work well with that.
pdlpsher1
by pdlpsher1
There’s no need to spend this much. A user here mated a 10-45 with a 105 RD. It worked fine without a roadlink.
prokyon
by prokyon
Where did you get a 10-45 12 speed cassette? The bike already comes with Di2, otherwise yeah I would just run 105.
pdlpsher1
by pdlpsher1
Shimano XT or XTR MTB depending on your budget. I wouldn’t use any cassette without a Shimano name on it.
prokyon
by prokyon
OK but those MTB cassettes are for MTB microspline freehub bodies - how would you fit that onto a road hub? For DTSwiss hubs, you'd essentially have to also get this, right? https://www.jensonusa.com/Dt-Swiss-Micr ... eehub-Body
pdlpsher1
by pdlpsher1
I can't open the link you gave. Watch this video for the correct part number to get. DT Swiss makes a special MS freehub kit that is designed for their 'road' hubs, to be used for their 12-speed GRX 1x group that uses MTB cassettes. If you just buy a standard MS freehub you'll get the MTB version made for MTB hubs, not road hubs. MTB and road hubs have different dimensions.
https://www.youtube.com/watch?v=D4VUWaPv6sQ
Here's the post by Upcountry on his 10-45 and 7150 RD setup.
viewtopic.php?f=4&t=175217
prokyon
by prokyon
Thanks, sounds like for both 11 and 12 speed can just fit an XT/XTR cassette. I wonder if there's anything special about using a 105 RD instead of Ultegra (other than lower cost) and if eccentric pulley wheels are needed - it looks like he wanted to try them. I'd actually probably use a GRX RD instead as it can tension the longer chain if needed - I had too much chain bounce on my 105 11-speed system.
Upcountry
by Upcountry
Hey there. Following up to my post that @pdlpsher1 posted...
I'm actually still running the setup I laid out, although I do have the parts sitting to make the move to Sram Transmission here in the next few days. I was somewhat hopeful that Shimano would release their GRX or XTR Di2 setups this year so was trying to get a little head start on that with the idea of just replacing the rear derailleur when it came out, but everything points to mid 2025. So with Sram releasing the updated Red E1 levers, I'm willing to head that direction. I previously ran a Force D2 XPLR setup on the same bike, but really disliked the ergonomics of the levers themselves, which was the main motivation for the attempts to make a 1x12 Di2 setup.
I did ride the 105 rear derailleur with stock pulleys for a few rides, and it was fine, although it took a bit of fine tuning on the B-limit screw to get the spacing off of the 45t cog just right. The offset pulley wheel made that much more forgiving. I chose this derailleur as at the time, it was the largest range di2 derailleur in their range(rated 2t larger than Ultegra or Dura Ace), as this was prior to the 2x GRX Di2 derailleur, which I would have opted for, simply to gain the clutch. You will need to swap to a Microspline freehub, but those are fairly available depending on your hub make.
One other option for cassettes is the Ingrid Components 11-44t cassette, which is available for either XD or HG freehub bodies.
pdlpsher1
by pdlpsher1
Thanks for the update. I didn’t realize this was a 1x setup. WhenI read 105 RD I just assumed it was 2x. I guess the 10-45 wouldn’t work on a 2x as the RD cage would be too short for such a big range.
NickJHP
by NickJHP
Why not just fit a different crankset with smaller chainrings and keep the standard 11-34 Ultegra cassette. This is the drivetrain on my randonneuring bike. It's 11-speed eTap rather than 12-speed Di2, but you could have the same sort of setup with 12-speed. The cranks here are some mid-1990s Deore XT MTB cranks fitted with 38/22 chainrings, and on the rear is a Leonardi 9-36 cassette. If I really want to push down a descent, 38-9 is good for about 70kph before I start to spin out, and 22-34 can get me up some astonishingly steep gradients - a couple of the short climbs I rode up in Switzerland recently got up to 25-26% gradient in places, and with that gearing it wasn't too much of a problem.
