Rim width for gravel
superpiki
by superpiki
Current trend it to go wider and wider with lower pressures.
How wide would you go, what you consider too wide?
Any thoughts of using mtb rims?
jdms2k
by jdms2k
32mm sounded nuts until Zipp did it.
Note that for gravel rim trends, it's both wide for lower pressure AND deep for aero.
CarlosFerreiro
by CarlosFerreiro
I suppose right now I see 25mm iw suiting current tyres. That might change really quickly if tyre designs start taking 25mm as a minimum design width.
From reviews of the Zipps it sounds like they have have maybe moved to a bit too much towards the bleeding edge for current tyres, but the next tyre cycle might sort the downside issues.
I'd like to try 27-28mm iw. It does all seem like it there will be changes happening as fast as new product cycles allow.
CampagYOLO
by CampagYOLO
CarlosFerreiro wrote:
Mon Sep 02, 2024 9:03 am
Given that a lot of the gravel racers are using 2.1" or bigger MTB tyres now, I'd say the Zipp wheels are the trendsetter and in a couple of years every brand will have similar wheels.
If it wasn't for Boost spacing then a lot of people would have been using XC wheels.
warthog101
by warthog101
I am uninclined to pay zipp prices.
These may be an alternative for others too
https://www.nextie.com/customize-your-o ... l-wheelset
CarlosFerreiro
by CarlosFerreiro
The move to a setup a lot wider than 45mm looks to have lots of momentum, but beyond the tyre and rim issues there aren't that many race gravel frames where well over 50mm tyre width is comfortable? That's another part of the design cycle - folk may go for the widest that fits, but what's available is still a fairly big limiting factor at the moment? Sram 1x13 is about the only thing lately that helps cram wider everything into road drivetrain constraints?
I'd see it as a period of flux, buy and try anything, but it'll be a little while before things start to settle down.
Last edited by CarlosFerreiro on Mon Sep 02, 2024 8:12 pm, edited 1 time in total.
jdms2k
by jdms2k
I bought 29mm Btlos.
Light bicycle - 30
Nextie - 29
Reserve - 27
Parcours- 27
OtterSpace
by OtterSpace
If you can fit it lightbicycle WG44 30mm hooked inner & 40mm outer is very nice with 38 marked 42 WAM tires.
Came out around a year before the Zipp 32 hookless inner & 40mm outer.
kofsw4
by kofsw4
jdms2k wrote:
Mon Sep 02, 2024 6:08 pm
Light bicycle - 30
Nextie - 29
Reserve - 27
Parcours- 27
What are your thoughts on the BTLOS now? What depth did you get and what was the weight?
FreaK
by FreaK
Depends on your priorities. Also what tyre size you're tending towards. I do feel like there's a bit of a ride quality penalty with an overwide rim despite the volume bonus. But if aero is a factor to you then wider rims are the best way to square the circle.
it's actually possible to come to the conclusion even before realising it makes no sense at all
tymon_tm
jdms2k
by jdms2k
kofsw4 wrote:
Wed Dec 04, 2024 6:45 pm
Light bicycle - 30
Nextie - 29
Reserve - 27
Parcours- 27
45mm depth. Weight with 240 hubs is 1452g (doesn't have drilled holes or tape).
My two fav things about running wider internal width wheels are (1) my 42mm pathfinders became 47mm and (2) my gravel tire pressure is around 27 PSI so rides are much more comfortable. I don't know if I got any aero benefit.
I didn't realize until after I ordered that the BTLOS wheels are hooked. I would prefer hookless for even lower tire pressure. I also would have liked wider external...something like 40mm instead of 36 for potentially more aero benefit.
One unexpected con is my setup catches crosswinds more often. I think it's because the rim (45mm) and tire (47mm) total about 92mm. If this was a road setup with 28mm tires, that would be similar to running a 60mm rim.
kofsw4
by kofsw4
Light bicycle - 30
Nextie - 29
Reserve - 27
Parcours- 27
Thanks for the feedback. I assume your weight is for premium rims (rather than extra light)? I've been quoted 1400g for 45/50 extra light rims on their in house hubs but might reconsider given your stability comments.
I only have 45mm clearance in my frame so will run 40c tyres that hopefully blow out to 42-43mm.
Liked 36mm width to balance some aero benefits against potential rim damage if they're too wide but honestly mostly interested in something that will look cool :)
Sent from my CPH2305 using Tapatalk
jdms2k
by jdms2k
I might have been one of their first orders for that rim. There was no extralight option when I ordered.
They're huge and cool looking rims. Then I saw the XPLR wheels, which are even wider and deeper.
LittleBobcat
by LittleBobcat
I'm currently working on a 28mm iw rim with friends in Xiamen. 50mm depth, symmetric with max ow 38mm & 34mm ow at hook. Would come with 28mm hooked & 29mm hookless option. The rim being manufactured by EIE, should be on market soon or already (shxx even from the same place i dont understand how they sell these stuff out)
the 28mm iw choice went after some aero & weight research and tire combination experiments which i personally think would be the sweet spot for current gravel riders. The WAM of tires would be more predictable and the threads shape would stay more like how tire manufacturers want them to be which i think is quite important to get decent performance unless you always run on tires dedicated for the wheels, just like what ZIPP goes for. For gravel, i think the tires are falling behind the wheels with still old standards for rim-tire combination and i don't see a quick transfer in the next 2-3 years. Afterwards some 30-ish width for gravel would be the norm maybe.
cerro
by cerro
jdms2k wrote:
Thu Dec 05, 2024 11:14 pm
Light bicycle - 30
Nextie - 29
Reserve - 27
Parcours- 27
Why would you run lower pressure with hookless than hooked?
