Good value XC/Trail one-piece carbon cockpit?
I just bought used Supercaliber and want some 1-piece carbon bar-stem combo for it.
Any proven solutions from reputable chinese company?
No aliexpress please (no warranty and questionable QC)..
Or better to go for something like Syncros?
https://www.syncros.com/us/en/product/s ... ed-cockpit
That syncros looks like it has a built in top cap for the internal cable routing. That's about a 56mm upper bearing. The Trek uses a ~41mm? It won't look great - not sure how it'd work. This might be the fix https://r2-bike.com/SCOTT-Ahead-Cap-and ... -Stem-Unit (or similar kit)
Have a look at Pro's Superlight stem for the weight or Syntace Flatforce for the drop ....and whatever bar makes sense. You can save about 40gr going with a 35mm bar, but then you just add that to back to the stem. You're probably going to get the most cost effective solution out of the Trek bar.
Sorry mate I forgot to mention it must be bar-stem one piece combo, mostly for look and stiffness. Weight is not so important but it would be nice to shave few grams off.
Supercaliber Gen1 has externally routed housings so I will not bother with internal routing options.
I have 2 Syncros bars for sale if you are interested, for the previous generation Scott bikes, that have external cable routing.
This one
https://www.syncros.com/us/en/product/s ... 1940135375
with 60mm stem
and
this one
https://www.syncros.com/us/en/product/s ... 1930135368
This one
with 60mm stem
and
this one
If they are new I'd be interestedTheBelgian wrote: ↑Fri Aug 30, 2024 7:46 amI have 2 Syncros bars for sale if you are interested, for the previous generation Scott bikes, that have external cable routing.
This one
with 60mm stem
and
this one
Bontrager combo seems to be as good value and weight as you can expect without paying exotic money.
They seem to review as being very stiff which has been noted as a negative, but if that is what you are after then they could wourk for you
Thank you both, i had a look.
Bontrager would match the bike better obviously but bike ahead look good too.
I have also found Syncros Hixon IC SL in sale, but I don't like the top cap garmin mount system.
Botreger front mount looks much better
I'm not a bike shop. I don't sell new partsRoadrocket wrote: ↑Wed Sep 04, 2024 9:09 pmIf they are new I'd be interestedTheBelgian wrote: ↑Fri Aug 30, 2024 7:46 amI have 2 Syncros bars for sale if you are interested, for the previous generation Scott bikes, that have external cable routing.
This one
with 60mm stem
and
this one
"Any proven solutions from reputable chinese company?"
Obviously not reading-compehension-weenies either.
OP - Bontrager RSL is a lot lighter than the Syncros and often available on sale for much less if you want reliable QC (Gemini Propus have their own thread where half of them are broken).
Otherwise, Voicevelo https://voicevelo.com/products/vfv-xc1- ... tsId=10008 is 210g.
Or the aliexpress best option might be a Rpahanti or Firespider (RYET Premium brand, but lots of people find RYET pretty reliable).
I’d like to see a comparison of their stem vs something like a Darimo IX2AL.Sock3t wrote:The bontrager RSL is hard to beat as-is the Roval cockpit.
The smart move still is the new Allied bar and stem setup, they're lighter than all one piece setups without being a noodle like the others.
