Helium-gas filled frames and tyres, anyone tried it?
General Cycling News Chat. No off-topic chat please
Higgs2011
by Higgs2011
I was looking at my bike and it will cost me about a £groupsert and £wheels to get down from 7.5kg to 6.5kg methinks but then I thought Helium-gas is cheap so could I fill all the hollows with it to make my bike lighter? What do you guys think? (there might be some maths involed somewhere I'm sure lol) . . . has anyone thought of this or tried it?
Karvalo
by Karvalo
Leaving aside the practicalities (or impossibilities) of keeping the helium on the inside, 1 litre of helium is 1 gram lighter than 1 litre of air. How many litres of air do you think are inside your bike?
Higgs2011
by Higgs2011
Karvalo wrote:
Wed Aug 28, 2024 8:45 pm
Ahh good, so it's worth doing !!! There must be a way forward.
BdaGhisallo
by BdaGhisallo
I don't know about helium, but I recall one pro team using nitrogen to inflate their tires. I think it was Telekom, iirc.
Karvalo
by Karvalo
Not for weight though, it's more or less exactly the same as standard air. It supposedly seeps out ever so slightly slower.
goodboyr
by goodboyr
Hydrogen is even lighter than helium, and if you're lucky it will give you a rocket powered boost.
Sent from my SM-S918W using Tapatalk
BdaGhisallo
by BdaGhisallo
Karvalo wrote:
Sun Sep 01, 2024 8:13 pm
Exactly - less pressure loss over a day's racing.
C36
by C36
Eddy Merckx did it for his hour record.
I have a claimed 7g gain on top of my head for the tubulars.
And the molecule being so small, pressure drop is quite faster than with “air”
Karvalo
by Karvalo
I saw that he wanted to but couldn't? If each tyre contains a litre of air then you'd save around a gram per tyre compared to air for each bar you pressurise them to. 100 psi / 7 Bar would be 7g per tyre, but what did they use on the track those days, somewhere from 10 to 15?
Surely it's a terrible idea though, and the pressure loss and rolling resistance would have made it worse than useless.
UpFromOne
by UpFromOne
Why discuss which gas is best, when you should do away with the material altogether...just vacuum-seal your frame!
Might not be a good idea on the tires though :lol:
uraqt
by uraqt
nitrogen, was used becasue of the heat ... there is less water in it so it heats up less.. lessing the risk of a tubular glue failing :)
C
EtoDemerzel
by EtoDemerzel
Nitrogen has larger molecules and deflates slower than compressed air.
No moisture content, inert gas, and prevents oxidation. Important for airplanes and F1 cars but meaningless for a bike.
Air is 80% nitrogen and bike tires won't last long enough for internal oxidation to matter.
Nitrogen fill is a good profit for service dept's where car owners will pay $200 for an oil change. Usually they even give you a special green valve cap.
Karvalo
by Karvalo
uraqt wrote:
Thu Sep 05, 2024 12:25 am
First, we were talking about a track bike. It has no brakes. How hot was it going to get?
Second, is that actually true? The specific heat capacity (amount of energy needed to raise 1g by 1°) of water vapour is nearly twice that of dry air or nitrogen gas. For a given amount of heat energy input, pure water vapour would stay much cooler than dry air/nitrogen gas, and a certain mass of humid air would stay slightly cooler than a certain weight of dry air/nitrogen. Now humid air is also less dense, so there would be less mass inside the tyre to heat but at ISA the difference in density between vapour and dry air is less than the difference in specific heat capacity, so I would assume that on balance humid air heats up ever so slightly slower under the same conditions.
usr
by usr
Karvalo wrote:
Thu Sep 05, 2024 8:02 am
The nitrogen sub thread isn't about the Eddy hour, it's about (perhaps) Team Telekom out on the road:
BdaGhisallo wrote:
Sun Sep 01, 2024 10:44 am
Karvalo
by Karvalo
usr wrote:
Thu Sep 05, 2024 9:40 am
Ha good point, I had lost track - sorry!
Still though - as I said I think it is (although a neglible effect all things considered) the other way around. Water is one of the best substances in the natural world at absorbing heat energy for a low rise in temperature.
