Forum rules
johnpuga1982
by johnpuga1982 on Wed Jul 03, 2024 10:10 pm
If anyone is interested or hasn't heard, Continental just released their new "Aero 111" tires. They come in two sizes, 26 and 29mm. Limited distribution in the U.S. and Europe.
Introducing the AERO 111 – the next generation in tire performance, developed in collaboration with DT Swiss and Swiss Side. Featuring an innovative and aerodynamically-optimized tread, this tire is engineered to effortlessly cut through the air like never before. The tread's 48 precision-formed, vortex-generating cavities create controlled turbulence, ensuring prolonged airflow attachment to the rim, resulting in reduced aerodynamic drag and improved crosswind stability.
The AERO 111 also incorporates all the winning technologies from the GP5000 TR Family: Black Chili Compound for superior grip and minimal rolling resistance, coupled with the trusted Vectran Breaker for added puncture protection. It’s the ultimate aerodynamic tire – without compromise.
The aero-optimized tread pattern certainly looks different: 48 little cavities are regularly distributed over its surface. These so-called ‘vortex generators’ are the very feature that manage to control the turbulence in the airflow on the surface of the front wheel. Ultimately, this results in a perfected storm that allows for the reduction of drag of the entire wheel tire system.
You can read more here:
https://www.continental-tires.com/produ ... /aero-111/
johnpuga1982 on Fri Jul 05, 2024 12:46 am, edited 1 time in total.
spartan
by spartan on Wed Jul 03, 2024 11:19 pm
interesting if Pogo will use these new super tire in the ITT coming up this week at the TOUR
Current Rides:
2025 Giant Propel Advanced SL 9270
2023 Tarmac SL7 Di2 9270
ex 2019 S-works SL6
ex 2018 Trek Madone SLR Disc
ex 2016 Giant TCRAdvanced Sl
ex 2012 Trek Madone7
Jaisen
by Jaisen on Thu Jul 04, 2024 8:14 am
BigBoyND wrote: ↑Thu Jul 04, 2024 7:02 am
So TT TR is still faster between -/+10 deg?
From a drag/aero perspective the new tire is faster across the board, so we will need to wait for the BRR test to see how they stack up in terms of rolling resistance. Given how close the new tire is between +/- 10 degrees of yaw, the rolling resistance will matter there. Go vote for it to be reviewed.
BigBoyND
by BigBoyND on Thu Jul 04, 2024 9:04 am
In another article it was stated that the construction is between S TR and TT TR. The weight seems to indicate the same.
-/+10deg the drag difference is much less than the RR difference between S TR and TT TR. It's rare you'll be outside that range. Even more so if you're a pro tour rider in a TT.
I already put in my vote this month for a different tire, but I have no doubt the Aero111 will win in the monthly votes category anyway.
johnpuga1982
spdntrxi
by spdntrxi on Thu Jul 04, 2024 7:14 pm
TobinHatesYou wrote: ↑Thu Jul 04, 2024 9:37 am
It’s basically a Kona tire where speeds will be modulated and wind speeds will be high.
exactly how I described it to my riding buddies when they mentioned it. Rather get a GP5000TT
2024 BMC TeamMachine R
2002 Moots Compact-SL
2023 Pivot E-Vault x2 drop and flat bar
tiz92
by tiz92 on Fri Jul 05, 2024 6:38 am
Its very costly and I would wait some independend testing. They claim relatively high watt saving, nearly unbelievable tbh. But we will see.
johnpuga1982
by johnpuga1982 on Fri Jul 05, 2024 3:20 pm
spartan wrote: ↑Wed Jul 03, 2024 11:19 pm
From the photos I've seen, looks like Pogi is running the TTs for today's TT. However, the back tire seems to have the model number blacked out.
- Pogačar TT setup
- Pogačar TT rear wheel
BigBoyND
by BigBoyND on Sat Jul 06, 2024 8:21 am
toxin wrote: ↑Fri Jul 05, 2024 4:44 pm
They arent sponsored by conti or swiss side so probably dont have access yet
They don't have internet access for someone to get a few sets on bike24? They buy a bunch of non-sponsored equipment.
Though I guess they'd need time to test it, too.
