EKOI PW8
https://www.youtube.com/watch?v=ZfdEOOEYmm0
true innovation. metal cleats wide platform only issue we need to buy new shoes
Current Rides:
2025 Giant Propel Advanced SL 9270
2023 Tarmac SL7 Di2 9270
ex 2019 S-works SL6
ex 2018 Trek Madone SLR Disc
ex 2016 Giant TCRAdvanced Sl
ex 2012 Trek Madone7
ex 2019 S-works SL6
These look pretty sweet! A great option for those who are interested in having a lower stack height as well.
System looks great. But Ekoi's shoes suck ...
Are Specialized, Shimano, Lake, Bont etc going to produce shoes to fit it? Almost certainly not, so it's going to be of very limited interested.
Arkea aren't using them because the riders didn't want to use Ekoi's shoes.
Am excited about these. I think in aero terms, they will be even better than speedplay. Have not seen the weight but it's not hard to believe that the system weight will be very good as well.
Changing the shoes is the only issue - and not a small one. But it's not gonna kill me to try.
- wheelsONfire
Question they should address, how do you mount shims on the shoes/ cleats?
I like the concept, but when you are forced to a specific shoe for a specific pedal, i kind of sense this is a doomed invention.
Bikes:
Open *UP* (2016.04.14)
With the new Outlier pendulum MTB flat pedals making the blog rounds, it seems like ekoi missed a trick here, as they could have made these pedals literally zero stack by removing the middle support that aligns with the pedal axis. Then again you have to wonder what the point of the lower stack is. If it's just to lower the total body position, then get a lower BB. The limiting factor on lowering bb is actually the pedaling clearance. Do they have speedplay beat there? I'm guessing not.
The Frenchie in the video said that having your foot closer to the axis of rotation makes your pedal stroke more efficient, which is an effect you couldn't get from dropping the bb, but is this a real benefit or just marketing talk?
proffate wrote: ↑Sat Nov 30, 2024 6:49 amWith the new Outlier pendulum MTB flat pedals making the blog rounds, it seems like ekoi missed a trick here, as they could have made these pedals literally zero stack by removing the middle support that aligns with the pedal axis. Then again you have to wonder what the point of the lower stack is. If it's just to lower the total body position, then get a lower BB. The limiting factor on lowering bb is actually the pedaling clearance. Do they have speedplay beat there? I'm guessing not.
Well... either your shoe sits on top of the oversized bearing and you incur a stack height penalty anyway -OR- your shoe sits outboard of that oversized bearing and you incur a q-factor penalty. Bumping your stance-width by 2x6mm is far worse for your CdA than a 12mm increase in stack height.
As long as the design requires a special sole, add a notch to house the bearing. I think you could put the bearing in the crank as well, some old shimano system apparently did this. But my broader point is that there's no actual reason to do any of this, at least that I've come to understand.TobinHatesYou wrote: ↑Sat Nov 30, 2024 7:06 amproffate wrote: ↑Sat Nov 30, 2024 6:49 amWith the new Outlier pendulum MTB flat pedals making the blog rounds, it seems like ekoi missed a trick here, as they could have made these pedals literally zero stack by removing the middle support that aligns with the pedal axis. Then again you have to wonder what the point of the lower stack is. If it's just to lower the total body position, then get a lower BB. The limiting factor on lowering bb is actually the pedaling clearance. Do they have speedplay beat there? I'm guessing not.
As to your point on stance width, spec tested it (normal vs "narrow as we can readily make it") and the difference was pretty negligible, at least as a solo rider. In comparison a 12mm difference in stack height means your head tube, seattube/post etc is 12mm shorter, not to mention you're effectively behind a slightly taller rider every time you draft, which sounds less negligible to me but I don't know if there has been any specific testing that didn't introduce confounding factors.
Pre-orders are open.
https://www.ekoi.fr/fr/1294-pedales
Remains expensive...
(Code WELCOME20 for -20€)
