Clik Valve
Forum rules
pushpush
by pushpush
Putting this here as it is wheel related. Mods please move if you disagree.
I'm torn between thinking this is a solution in search of a problem and thinking it might just be genius. I look forward to more practical reviews with real world use.
https://bikerumor.com/the-end-of-the-pr ... -standard/
jayjay
by jayjay
In theory it sounds great!
pushpush
by pushpush
I'm intrigued. If it can reliably tolerate sealant and works as described it could be pretty nice.
poulhansen
by poulhansen
Sounds really good. Bigger internal diameter, clicks on, adapters to both existing tyres and pumps.
https://clikvalve.com/collections/replacement-parts
Cannondale Super Six Hi Mod 2017 6.845 kg
Cannondale six13, 2004, 5.50 kg
Focus Izalco Max, 2023, 4.33 kg
Jaisen
by Jaisen
Looks very interesting, it's annoying to always have to lock and unlock the presta valve core before and after inflation. It's not a huge deal but anything that makes the process smoother is welcome.
AJS914
by AJS914
The only problem solved I can see is more airflow though, personally, I've never had a problem pumping up even tubeless tires with a normal presta valve. Pumping may be easier with a click valve and click pump. It seems like it would still be susceptible to getting clogged with sealant.
MikeD
by MikeD
Even though they say you can use a normal Presta pump head, it won't work as intended (I.e., won't click on). I'm not about to replace all my pumps or fit with new pump heads. For that reason, I'm out. The Bontrager adapters seem better in my opinion.
poulhansen
by poulhansen
I have to change a lot of valves and heads as well but will try anything to get rid of those big heads with a hard to close handle that either leak or jump off half the time and can't be wrestled off the other half the time. :-)
AJS914
by AJS914
poulhansen wrote:
Wed Jul 03, 2024 9:58 pm
The Hirame pump head changed my life forever, at least my cycling life. Contender for the best cycling accessory I've ever bought.
https://www.velominati.com/technology/r ... pump-head/
BigBoyND
by BigBoyND
Heads popping off or leaking air make me want to tri the clik system.
Now I don't know whether I should try Hirame for my Fillmore valves or go all in on Clik
TobinHatesYou
by TobinHatesYou
BigBoyND wrote:
Thu Jul 04, 2024 7:00 am
The side-lever clamp styles are pretty grippy if adjusted correctly. I use my Hiro in my AirShot up to about 170psi.
Don’t think I’d recommend the Hiro over the Hirame or Arundel Hansel though. Not sure about the ENVE/KCNC design.
There is some excitement over the Prestacycle Pro Presta head, but it’s really just a JACO head and it’s not nearly as secure as the side-lever style. It also doesn’t clamp onto minimally exposed valves.
BigBoyND
by BigBoyND
TobinHatesYou wrote:
Thu Jul 04, 2024 7:16 am
How about the force required to push it on and off the valve?
My Topeak Joeblow Twin Turbo head requires a lot of force to get on. Same for pulling it off, which makes me lose too much air sometimes.
TobinHatesYou
by TobinHatesYou
BigBoyND wrote:
Thu Jul 04, 2024 8:02 am
Zero force with the lever in the open position.
BigBoyND
by BigBoyND
Thu Jul 04, 2024 8:24 am
Wow, OK. I'll try that first!
gloscherrybomb
by gloscherrybomb
Price is very sensible too.
