Hey folks!
I wanted to ask for similar experiences and possible solutions. I do love my tubolito s-road TPU tubes for their weight, size and seemingly rolling resistance. But one major flaw is that I do get a static buildup while riding. Giving other riders electric shocks on contact and causing (my theory) excessive buildup of grime / dirt on the drive train. Above 6,5 bar / 94 psi the static build up reduces, but I want to ride at ca. 5.7 bar, which is the optimum silca calculated tyre pressure for me.
Have any of you found solutions to this very niche problem? Did any of you try different TPU manufacturers? Maybe some of them have different surfaces that are not as glossy/smooth as the turbolito? I did think about talcum powder, but I do not know if that would a) work and b) might damage the tube over time.
Have a good day!
Cheers
Experiences with TPU tubes and static build up
Forum rules
Stevens Arcalis - 2023 - 7.902 kg
Stevens Prestige - 2021
Radon R1 Road - 2015
KTM Lycan - 2014
KTM Lycan - 2014
He is not the first; there are occasional comments on the internet, but since it is a relatively new product (in comparison to traditional butyl tubes) and the effect is hard to track, I guess most people just ignore it if experienced occasionally.
I have been riding on TPUs for just over a year, and the static shocks are definitely a thing. The thing is, it is not very frequent and seems to depend on the road conditions.
For me, it was very hard to connect the static shocks to the TPU tubes. My observations are that the newer and cleaner the tarmac, the more shocks happen. Also, hot weather seems to help the buildup.
In extreme cases, I can even see a spark jumping from the metal lever axle of my STI shifter to my hand. Sometimes the shock occurs when you hit a wet patch on the road, usually those are hard too. Discharges also happen if you happen to touch the grass around the road.
My 2 most ridden bikes are very similar, both steel frames with exactly the same wheels, but one uses TPU and the other - butyl tubes. I have zero shocks on the butyls and many on the TPUs.
Again, depending on the conditions, it may not happen for days, but it may happen a few times per minute.
I don't observe excessive dirt build-up. For me, the only problem is the shocks, which can be very annoying at times.
as marsa said, it still seems to be a fairly niche problem. I've contacted tubolito directly in the meantime. Still waiting for a reply. They do have to know something about the problem. The static buildup seems to be really fast with my setup. One can touch me every few seconds and will be struck by a static shock each time. I could live with the shocks. But the build up of grime/dirt is really annoying me. My "good weather bike" gets ridden in the best weather/road conditions of all my bikes but has the dirtiest chain. I hate the thought of adding back the 150g+ to the frame, but I don't want an increased wear on the drivetrain...
KTM Lycan - 2014
KTM Lycan - 2014
