Like many of the more particular tinkerers in the hobby who had a preferred rim brake setup I’ve been in search of perfect disc brake feel and performance since the transition to flat mount disc. I haven’t found it yet but perfect is the enemy of good so its time to detail my 2000km+ journey with Shigolo for the community.
Personally I consider Shigolo to be an improvement over default Shimano ST road hydro setups, and Shigura, and I will not be swapping back. I first decided to give this a try after having previously using Shigura, seeing high praise of Campagnolo disc braking from multiple sources, and theorizing that Shigolo should basically be a modern version of Shigura given the its design lineage.
Some disclaimers first as I don’t want to derail and waste anyone's time who wouldn’t benefit from micro optimizing their Shimano setup given how verbose this write up will be:
- If you are fine with default Shimano ST hydro setup’s grabby brakes then stick with it as this is the main item that Shigolo improves with a few trade-offs. (see: performance)
- More specifically I would say that after initial pad engagement a full Shimano ST hydro setup lacks accessible low braking force across the remaining brake lever throw while bringing better usable high braking force than a good rim setup.
- My opinion of Shimano OEM road hydro performance being grabby is unchanged across the last three generations of Shimano hydro ST after having extensively ridden all of them since 2018 with their corresponding default series calipers:
▪ ST-RS685
▪ ST-8070 & ST-9170
▪ ST-7170 (Non ServoWave) & ST-8170 (“road” ServoWave) - I am too stupid mechanically to know why default Shimano ST hydro setups are so grabby (it certainly isn’t the road ServoWave deployment as I see this with both ST-7170 and ST-8170). However, Shigura and Campag braking systems don’t have accessible low braking force issues from user reports and personal experience.
- If you solo ride in a relatively flat place any hydro caliper, rotor, and brake pad will likely perform well enough unless you are extremely particular.
- If you didn’t come from rim brakes, which some facetiously call speed modulators, than you likely don’t miss how you could precisely scrub speed more easily with rim through the first portion of a lever throw.
- If your descents are not technical than you likely shouldn’t be overly concerned with brakes initially biting too hard.
- In comparison to 12s Shimano calipers the Campag calipers don’t retract as much when nonengaged and therefore Campag calipers are more susceptible to setup misalignment and thermal expansion of rotors which results in audible ticking from disc rub.
- SRAM road uses DOT fluid while Shimano, Campag, Magura, and Trickstuff use mineral oil. Due to this Campag calipers cannot be used with SRAM road shifters without a seal material change kit for Campag calipers which likely will never happen.
