Anyone make crank arm boots for SRAM Red Cranks
justonwo
by justonwo
Would really like to protect the ends of the cranks, which will undoubtedly get trashed.
2020 F12 AXS Red (Zipp 353)
2021 S-Works Aethos Di2 9200 (Alpinist CLX II)
2006 Cervelo Soloist
2021 S-Works Epic
2024 Topstone Lab71 (Force/XX1, Terra CLX II)
Retired: 2014 and 2020 S-Works Roubaix
2020 Canyon Ultimate
2018 S-Works Camber
jacobeh
by jacobeh
They will, especially if you have low ground clearance like I do on my Trek Checkpoint - on the other hand you will get some "free" weight saving with all the clear coating getting chipped away
Lelandjt
by Lelandjt
I'd expect Sram's boots for their carbon Mtn cranks to fit the carbon roads cranks. They look the same shape.
yinzerniner
by yinzerniner
Lelandjt wrote:
Tue Apr 16, 2024 12:47 pm
While they "fit" they will be loose. The mtb crankarms are slightly thicker at the pedal end so when you put the boot on its not a direct fit ; mind you it will stay on the crankarm ends when a pedal is installed, but unless the empty space is filled the boots will end up collecting debris and said debris could end up scratching the ends.
If the OP wants to try those boots maybe a decent bodge could be to heli tape the crankarm ends before installing the boots. Should be enough to take up the slack while also providing redundancy
apr46
by apr46
Worldwide Cyclery suggests the Large Raceface boots, part # CR8986
https://help.worldwidecyclery.com/hc/en ... y-crankset
I have not installed them on red cranks, so I personally cannot verify, but i have used other reccomendations from their list and have been happy.
JMeinholdt
by JMeinholdt
I used these on my Force AXS crank arms. Fit pretty well and dirt cheap.
https://amzn.to/4d5TOQC
Basso Palta II - SRAM Rival AXS 2x - Gravel
Wilier Cento10AIR - SRAM Force AXS - Road
YouTube link: https://www.youtube.com/@JMCyclingVideos
justonwo
by justonwo
Ok, so I found a solution that is workable. The RaceFace boots fit very well to the end of the Red cranks in terms of snugness. The problem is that the hole for the spindles doesn't quite line up. I removed small amount of material from the top end of the outside hole. This allows the spindle to snug up against the crank arm. I've removed so little material that I don't think the boot will be compromised.
On the hex side, the hole is ever so slightly out of alignment. If you use the wrench to push the plastic slightly to the side, that really isn't much of an issue. I suppose you could always remove material on that small hole as well, but it was easy enough to get the wrench in there to tighten the spindle.
2021 S-Works Epic
2018 S-Works Camber
JMeinholdt
by JMeinholdt
Those are some chonky crank arm boots. The ones I use are thin silicone. Plenty for errant rocks that can be kicked up riding gravel. One bonus is that the inside is a much larger diameter so there is no issue with fitting the hex wrench.
But, as long as they work for you, that's what matters. Nothing worse that rock marks on a high end carbon crankset.
justonwo
by justonwo
JMeinholdt wrote:
Mon Apr 22, 2024 2:35 pm
They aren't that big in person. Silicone isn't as durable a material for this purpose as the high density plastic.
2021 S-Works Epic
2018 S-Works Camber
kervelo
by kervelo
I wonder if the SRAM Transmission crank boots fit SRAM Red cranks too?
https://r2-bike.com/SRAM-Crank-Protecto ... ansmission
Uberflo
by Uberflo
These fit the RED Cranks:
https://www.zefal.com/en/bike-protectio ... or-xl.html
I have it on two bikes with E1 crankarms.
kervelo
by kervelo
kervelo wrote:
Mon Nov 04, 2024 4:05 pm
I got a pair of these boots and they fit much better than the older SRAM boots. The holes align almost perfectly, so there is no need to cut them at all. Some juggling was needed with one pair of SRAM Red cranks/boots when installing the pedals, but not with another pair.
