2024 Factor Ostro sighted
The general all-things Road forum!
tlcyclist
by tlcyclist
Zstar88 wrote:
Wed Nov 06, 2024 4:42 pm
Anyone running a garmin varia on their v2 ostro? If so, what mount do you use/recommend?
This link was posted by a member of Facebook's Factor Bike's Owner's group:
neat-components.com/LUCA10
I dont use a varia; or know anything about the neat components site. FYI anyway.
tlcyclist
by tlcyclist
macwatt wrote:
Sun Nov 17, 2024 7:31 pm
After several weeks deciding which bike to choose finally pulled the trigger on Factor Ostro VAM V2.
I thought all the difficult decisions were passed now it's the which dual power meter for Shimano 12 speed 🙄😂 wouid prefer to stick to Shimano chain rings to ensure smooth shifting.
I've emailed a few websites on any suggestions based on the above, 4iiii dual sided Shimano Precision 3 Pro + or Assioma power pedals is what I was thinking for easy solution will see what responses I get back.
Would be keen on knowing which of those you settled with. On the same boat with my ostro and power meters. Thanks!
macwatt
by macwatt
Hi
Still waiting for Factor to be built and delivered
Any chance someone could check clearance as per attached photo this is for 4iiii power meter install
Regards
Zstar88
by Zstar88
In the uk the main factor dealer - vires velo - sells Ostros with 4iiii power meters. So I assume the clearance is there.
wickedstealthy
by wickedstealthy
Yup running one like on all my bikes. I have an adapter under my seat attached to my selle flite boost saddle
Zstar88
by Zstar88
wickedstealthy wrote:
Wed Nov 20, 2024 4:36 pm
Sounds like a good solution. Any chance you can post a photo?
ferdiaz
by ferdiaz
That makes two of us. Just snatched a beautiful Ostro VAM V2 frameset, which I plan on building around a Dura Ace 9200 groupset.
Like you, I want a power meter, and I want Dura Ace chainrings, but I absolutely do NOT want the Shimano power meter. So after much deliberation, I've finally settled on the following:
- Dura Ace 9200 52/36 chainrings
- Sigeyi AXO power meter in Easton 4-110 configuration
- Elilee X310 crankset in 24mm configuration
That should give me Shimano shifting, at a lighter weight, and with a reliable power meter.
What have you decided in the end?
macwatt
by macwatt
ferdiaz wrote:
Fri Nov 22, 2024 12:31 am
Hi
My Factor will be built with Ultegra although I will be changing some drivetrain components to Dura Ace.
I'm intending to go with 4iiii Dura Ace Precision 3+
Pro Dual power meter 52 / 36 chainrings with 165mm cranks
https://shop-uk.4iiii.com/products/dual ... 5285871791
I've pre ordered at a discounted price
Power meter only adds 29gms to crankset total weight will be similar to your chosen parts.
Original Ultegra Crankset and cassette will be sold therefore this will be most cost effective power meter upgrade.
macwatt
by macwatt
tlcyclist wrote:
Mon Nov 18, 2024 3:20 am
Hi
Decided to go with 4iiii Precision 3 + Pro Dura Ace as weight will be similar to alternatives and for my build the cheapest option.
These are alternative options I got if you don't want to go with 4iiii
Rotor
https://rotoruk.co.uk/v1.asp?cat=1136&prd=272164 - 24mm BB
Or to go top of the shop Rotor make an independent left/ right meter called 2inpower SL (superlight)
Which has internal electronics in the axle so it has to be 30mm, which we can supply the BB for.
This can have the same rings with spider OR you can choose the superlight superstiff ONE piece double 52/36 rings which slide onto the spline..great power transfer and a super accurate left right dynamic
https://rotoruk.co.uk/v1.asp?cat=1136&prd=281199
Use BF2024 for an extra 15% discount
Or
Power2Max
We deliver VAT free and customs and shipping costs 29,-€ in your country you then pay your VAT.
We already have several customers who have successfully fitted a p2m to a Factor frame.
This would be the right link: https://www.power2max.com/en/product/ng ... -set-road/
Please order the p2m in BCD110 4S, then your chainrings will also fit. The ALDHU R24 is compatible with the Shimano bottom bracket.
wickedstealthy
by wickedstealthy
macwatt wrote:
Fri Nov 22, 2024 1:43 am
Hi
Rotor
Or
Power2Max
If you can shell out the money.
Stay away from the rotor powermeter as it has the same quirks as before. Check gplama
The only option I trust and I run that combo on 3 bikes is the rotor power2max option.
I still have a type s power2max of 10y old and reads the same as the other newer although the crank has already been involved in 2 accidents with cars
I have the rotor aldhu carbon cranks with rings and the 4sl spider. So if you want you could still use the shimano rings if you want
wickedstealthy
by wickedstealthy
Zstar88 wrote:
Thu Nov 21, 2024 10:34 pm
Here you go
AXA
by AXA
I'm running P2max since 3 years on my Ostro V1.
High quality power meter with the same shifting performance than Shimano crankset if you use original chainrings and you can also cut some weight. What else?
Zstar88
by Zstar88
Sat Nov 23, 2024 12:14 pm
Looks like a great solution. Which specific mount is that?
wickedstealthy
by wickedstealthy
Zstar88 wrote:
Sun Nov 24, 2024 10:45 pm
The guy is known on instagram TheStickyBottle who makes all those nice transition spacers for different bars to different frames
speedylumberjack
by speedylumberjack
My Ostro V1 was warrantied and replaced with a V2. No major ride feel/compliance differences noticed but enjoying it overall. I went away from the integrated barstem setup I had on my V1 to an internally routed mega narrow setup, the rest was carryover from my V1.
