If any of you would like to change the rear brake, I've installed a quite unique setup: Trickstuff C22 brake caliper with a Magura MT8 Carbon lever. I used Trickstuff Beta hose.
I cannot measure the final weight (internal cable routing 'rules'...(facepalm)), however, it is somewhere in the range of 175-185g range.
Started like this, Trickstuff banjo installed to the hose here, already:
...from an another angle:
Bionöl is its way, I filled the empty Trickstuff Beta hose here, initially:
...after filled the hose, closed it:
Some useful information: after connected the Beta hose to the Magura MT8 lever, I used the regular Magura method to fill the system, using Trickstuff Bionöl. Super simple and fast method.
Might be also useful: Beta hose has a slightly wider diameter than Magura's hose, therefore, fitting Magura's olive and stuff might be a bit more difficult - but works!
Everything is done, brake caliper aligned here (installed the rear wheel temporarity), front brake lever adjusted also. Works like a charm!
Might be also interesting, however not connected to brake installation by any means. I use this super simple and cheap method to avoid link damage which can be caused by little rocks coming to the gap between the frame and rear triangle.
