New Canyon Gravelbike?
smartyiak
by smartyiak
yinzerniner wrote:
Wed May 24, 2023 10:17 pm
...But even a not so long D-Shaped seatpost can provide comparable levels of flex as the double leaf spring if designed correctly, even when not a lot is exposed. ...
Also the double leaf spring design of the Ergon/Canyon posts are prone to some fitment/sizing and slipping issues - that's why they supply it with a carbon shim.
Just throwin it out there: we're gonna rely on Canyon to design a whole new seatpost (and frame interface) that functions correctly?
justkeepridin
by justkeepridin
robbosmans wrote:
Sun May 21, 2023 3:18 pm
love the full internal cable routing on that bike! any updated news about this bike?
henau212
by henau212
justkeepridin wrote:
Thu Jun 01, 2023 12:41 am
It is not fully internal, as you can see in other pictures. The cables are routed out of the handlebar, directly beneath the stem and into the headset. Clearer pictures ca be found over here https://www.mtb-news.de/forum/t/canyon- ... t-18766867
robeambro
by robeambro
Not a great picture but yeah, looks like Jasper will definitely race it at Unbound
https://ibb.co/cr9B9kQ
henau212
by henau212
New infos from unbound:
- UDH mount, there is a picture with transmission
- additional mount under bottom bracket (also on and under top tupe)
Edit:
a new video showing the bike https://www.youtube.com/watch?v=-k4EgtyVCzE
kervelo
by kervelo
robeambro
by robeambro
I like the frame shape, but I think there was no need for a D-shaped seatpost and the cockpit is possibly the ugliest I've ever seen.
DrimeOser
by DrimeOser
Ugliest cockpit? I think that price goes to the Grail.
henau212
by henau212
More pictures and info incoming (German): https://www.rennrad-news.de/news/gravel ... rail-2023/
- direct mount for a speedmax like flatbar
- mounting option under the top tube seems to be for a frame bag..
maurice1
by maurice1
They already make the hideous front frame bag for the current Grail https://www.canyon.com/en/gear/accessor ... 01610.html
I like that they are at least moving to bolts to replace some straps, but isn't that shape pretty awful aerodynamically? Wouldn't a front triangle bag be better? Or even the box cube makes for their litening C62?
robbosmans
by robbosmans
Does look nice
Reminds me of this
mrlobber
by mrlobber
At first glance, looks a bit like Ultimate on steroids.
yinzerniner
by yinzerniner
mrlobber wrote:
Mon Jun 05, 2023 5:06 pm
That's been mentioned a few times already in this thread
Also funny how that article rerencez Ben Delaney as the source, since he used to be at Bike Radar until I believe he was let go
From his extensive vids/pics:
-like the Sram UDH
-bars have a distinctive anchor/hammerhead shape, even though not as wild as the Coefficient
-also the bars have a tight bend and flare out a lot. The flare doesn't seem to be multi angle/varied, so the shifters take on the tilt of the drops instead of staying more vertical. Or maybe it's just that every pro rider in the vid now uses severely tilted shifters
-good number of mounting points
-looks to have some sort of rubber or plastic gasket around the hoses after they go down through the cutout of the top cap.
-would be surprised if tire clearance was rated for anything bigger than 700x42mm with 6mm clear. The rear looks especially tight, and even the fork crown is moderately close to the tire compared to other forks
-no flip chip for adjusting wheelbase or fork rake. UDH doesn't allow for it in read I believe
-don't see any fender/rack mounts
-interesting that the 1x aero chainring works with the Eagle transmission chain, RD and cassette. Sram said at release that Transmission requires a 55mm chainline (52mn road equivalent, since the rear hub on road is 142mm vs 148mm mtb boost), and Sram red axs crankarm only comes in 145 or 147.5mm in limited, Lauf-only custom guise
NordicSal
by NordicSal
New Endurace?
thirdsun
by thirdsun
The new Grail will be released very soon since it already made its way onto Canyon's Coming Soon Page: https://www.canyon.com/en-de/coming-soon/
Usually bikes shown there will be available within a few weeks.
