2023 Enve Mog
CFrancis515
by CFrancis515
Finally got my MOG back from the painter and built up. Painter shaved the luggage mounts off the front fork for me as well!
56c MOG
ENVE 4.5 wheels
SRAM XX SL 170mm Cranks
Quarq Power meter spider with 42T Carbon Ti Ring
Sram XX SL T-Type Rear Derailer
Sram XO T-Type Cassette 10-52T
SRAM Force D2 Shifters and Brakes.
SRAM AXS XPLR 75mm Dropper Post, Not Pictures
Egg Beater Pedals
1-Piece Carbon Cockpit off of Ebay, 40cm at hoods 46cm in the drops
SWorks Power Mirrior Saddle
Custom Mettalic Purple to White Fade Paint
Currently has 35c TerraSpeeds on from BWR San Diego, will be swapping for 45c WTB Riddlers this weekend.
https://ibb.co/L6ZKbSy
https://ibb.co/NVxfh8X
boots2000
by boots2000
Just got my Mog. Don't know where the 900-950 gram frame weight comes from. My frame out of the box weighed over 1100 grams ;)
Knightyboy27
by Knightyboy27
boots2000 wrote:
Wed May 08, 2024 4:51 pm
No hardware?
From their website -
What is the weight of the MOG?
Frame Weight: 950g (56cm, Painted, No Hardware)
sigma
by sigma
Knightyboy27 wrote:
Wed May 08, 2024 10:13 pm
No hardware?
hmm I have a Slate Blue in 56 coming soon so I will weigh mine and report it here. I would give them a call. They have terrific customer service and the new owner(s) are real bike people, so they should have an easy chat with you and maybe swap that out.
Deciding between Transmittions xx-SL and Red Mullet / Explr build right now. Don't know if any of you guys went through the pros and cons but I would welcome thoughts.
Lots of bikes: currently riding Enve Melee, Krypton Pro, S Works Crux, S Works Epic Evo, SL7.
In build: SW SL8
Requiem84
by Requiem84
Chipping in here as well. Any experience to use the Mog as both a gravel bike and road bike?
I'll be keeping my Canyon Aeroad for the rally racey stuff, but I'm looking for a bike that I can bring on cycling trips where I'll do both gravel and road, typically places like Girona, Mallorca, French / Italian Alpes / Dolomites etc, where it will be 60% road, 40% gravel. But I also need something that can race stuff like the Traka 200.
Is this my unicorn? :D
boots2000
by boots2000
I just rode my Mog in an event and I used 29x2.1 Thunder Burt tires. They have adequete clearance in the bike, but they wouldn't be my choice for a muddy course.
There is good and bad to using the wider tires. The good is that they can run at lower pressure- So less chance of punctures, more comfort and feels stable on open descsnts.
The bad- Thye feel cumbersome cornering and tip over to toe ovelap (on a 54cm with 172.5 carnks and size 45 feet). I do not have this issue with 700x45.
So I am going back to 700x45 or 700x47 for most of my riding.
The day after the event I did a 90% gravel, ~80k ride with all surfaces, chunky to smooth. I liked the 29x2.1 for this. No switchbacks so I never thought of overlap.
mfa81
by mfa81
No hardware?
Mine is built with a force d2/xxsl mullet setup, I never considered xplr since I’ve heard rumors of the clutch not being strong compared to eagle/t-type. I’m not too particular with cadence since I’m not holding 23mph speeds offroad, you can also until red e1 xplr shows up use udh direct mount only with t-type which makes setup a lot easier! I’m usually on a 46 or 44 ring and both ise the same size chain with t-type
mfa81
by mfa81
Requiem84 wrote:Chipping in here as well. Any experience to use the Mog as both a gravel bike and road bike?
You probably want a Fray, but you gonna run into tire clearance problems with a 2x setup.
I’ve ridden the MOG with 4.5s and gp5k as tr 35mm a lot during the winter on bike paths and the MOG is definitely a much better gravel bike than a road bike, feels a bit slow getting up to speed and handling!
If you are happy with 40mm tires you might get away with the FRAY on a 2x setup but clearance will be a bit limited I believe!
Requiem84
by Requiem84
mfa81 wrote:
Thu May 23, 2024 2:00 am
Thanks for thinking along with me! :). Ideally I'd go for a 2x set-up indeed as it's more enyoable on the road. The Fray is listed as max 38mm with 2x, that will be a bit on the small side for things like the Traka. My other option is an Ostro Gravel, but I suspect the Mog/Fray will be more fun on gravel.
sigma
by sigma
CFrancis515 wrote:
Mon May 06, 2024 6:48 pm
56c MOG
ENVE 4.5 wheels
Egg Beater Pedals
Quick question for you - were those the cranks that came with the Transmission groupset? If so, were you able to fit the 42T chainring without issues wrt clearance or otherwise? thanks!
In build: SW SL8
mfa81
by mfa81
sigma wrote:
Sat May 25, 2024 5:36 pm
56c MOG
ENVE 4.5 wheels
Egg Beater Pedals
The questions wasn't for me but I'm running a 46T ring on a road wide crankset which is narrow q factor than xxsl crank even the narrow version, running any t-type or road wide you should have no problems running a 42t ring
CFrancis515
by CFrancis515
56c MOG
ENVE 4.5 wheels
Egg Beater Pedals
Yes, they are standard MTB DUB width, which is about the same or 1-2mm wider than a set of road DUB WIDE cranks. So tons of room to play around with chainline and tire clearance. I currently have a set of 45c TUFO Gravel Thundero tires on it and there is still tons of clearance with the 42T ring. Im confident i could fit a 50T if i wanted to!
CFrancis515
by CFrancis515
Cant figure out how to get the damn photo rotated the right way, but you can see the clearnce in the photo is ample.....
mfa81
by mfa81
I'm running a 48 thundero on 25mm id AG2 wheels and a 46T chainring on a sram road dub wide
CFrancis515
by CFrancis515
Fianlly got my hands on a set of the new Red Shifters and brakes also!
