2023 Enve Mog
boots2000
by boots2000
Frame with hardware but without thru axle was ~1100-something (as I recall). Lighter than my Checkpoint, heavier than my Crux.
ckchriskohl
by ckchriskohl
boots2000 wrote:
Mon Aug 19, 2024 5:09 pm
thanks yo much.
Vilsheimer
by Vilsheimer
mogmog wrote:
Tue Feb 06, 2024 11:28 am
Hey guys,
happy to present my new Mog. Custom painted with the inspiration of a Land Rover defender as a full do it all bike.
Laced up with 3.4 ARs with CK hubs and a 1x 42T-10/52. Already raced it here and was really impressive to see how the bike handles and how stable & fast it can be compared with my old 3T exploro.
https://imgur.com/a/k6ZoUEe
Hey mogmog - digging this back out.
Do you mind comparing the gravel capabilities of the two bikes a bit further?
I'm also looking to make my Racemax an AR bike and thinking about adding a proper gravel machine next to it. N+1.
Wondering if the mog with 48mm tyres could live up to that - or if it's a too stiff racy gravel bike (again) which wouldn't handle my sketchy alpine single track terrain very well.
Thanks!
(Obviously feel free to add insight everyone else)
JHeiro
by JHeiro
Done a couple of rides with my new MOG. Built with Red XPLR 1x13, Zipp 303 XPLR SW, Schwalbe G-One RS 45mm, Enve AR bar. Might just be my favorite gravel bike right now: fast, comfortable, handles nicely. I also have an S-Works Crux, S-Works Diverge STR, Ridley Kanzo Fast and 3T Exploro Racemax on my fleet.
Will post a more thorogh review once I've got some more rides with it.
Co0kieMonster
by Co0kieMonster
It may be a dull question, but is the MOG meant to be ridden with a short or with a long stem ?
I am 175 cm ("long" legs, short torso) and as usual uncertain if I should go for 52 or 54. Got a really good offer atm ...
My Factor Ostro in 52 fits perfectly.
jayjay
by jayjay
JHeiro wrote:
Fri Sep 20, 2024 5:51 pm
Looking forward to your review!
Co0kieMonster wrote:
Fri Sep 20, 2024 6:35 pm
I compared the geomerty with my current gravelbike and I would need a 1cm shorter stem.
pushpush
by pushpush
Do you know of a source for colored plugs for the mounting holes on the fork? I have a sand colored frame and would like to conceal the black dots on the fork legs.
pushpush
by pushpush
I opted for some Ti set screws. A little dab of blue to keep them in place and they sit flush with the mounting holes. I was disappointed to realize that the way Enve made the frame they protrude from the surface of the frame rather than be totally flush. Not a big deal and if there were anything mounted to these holes it would be a good thing to keep the mounted object (cage/rack/bag/whatever) from rubbing the frame, but with nothing mounted it looks a bit dodgy.
I forgot to weigh the stock bolts to compare to the set screws but I'm sure it saved some grams to appease the WW gods.
pushpush
by pushpush
Has anyone else experienced a rattling/knocking sound when riding over chunky rough stuff? At first, I thought it might be a loose headset or the chain. Through a process of elimination, I was able to isolate the sound to the storage hatch cover. It only occurs when a full bottle is in the cage mounted to the cover. It happens with or without items stored inside the frame. I have not yet engaged Enve.
boots2000
by boots2000
Is anyone running a 2x12 SRAM Red E1 groupset (with 33/46) on your Mog? Any clearance issues with front derailleur?
hansotto089
by hansotto089
Anyone has a photo of a MOG with 60cm frame?
pushpush
by pushpush
hansotto089 wrote:
Tue Oct 22, 2024 6:53 pm
no, sorry. Mine is a 56.
pushpush
by pushpush
pushpush wrote:
Tue Oct 15, 2024 3:55 pm
A lot of adjustments and trial and error and it turned out to be the Silca Ti cages. With a full bottle I guess they flex enough to knock against the frame. Kind of makes sense in hindsight, I pulled them from my SL7 last year because they kept ejecting bottles over rough sections of road. --- Swapped them out for some Enve composite cages and the issue is resolved. Now I just hear the chain flopping around over the chunky stuff like one would expect when you ride the wrong bike for the conditions...errr.... I mean ride a gravel bike. :)
pushpush
by pushpush
EDIT:
I was trying to figure out how to improve chain line and which pm to use.
I have an Easton Road spindle, Sigeyi Axo Boost pm, and absoluteblack chainring. The resulting chain line is approx 48. I had heard that clearance can be a problem, but there is plenty of clearance between the PM and the frame. Success.
MAsshole
by MAsshole
https://www.reddit.com/r/gravelcycling/ ... _enve_mog/
