2019 Spark 2 position rear shock?
MC356
by MC356
Hi Everyone.
Im in the process of building a 2019 Scott spark, bought the frame-set and will be putting my own parts on it.
Only problem I have is i will be using a Rockshox SID ultimate SL (32mm) fork that has a 2 position lockout. I know I can buy the 3 position damper from Scott but they don't have any in stock and have no idea when they will. From what I have read its going to be hard to find one.
So I am thinking of changing the rear shock to be a 2 position one instead of the 3 position one and running a oneloc instead of the Scott twinloc. I know the shock I need would need to be 165x40 trunnion mount and wanted to see if anyone on here has done this before? There seems to be only 3 position 165x40 shocks out there. Would I be able to run a 165x42.5 shock, they have those in 2 position...
Thank you in advanced!
BMC TMR01
Niner Air 9 RDO
snaxez
by snaxez
Fox factory 165x40 DPS trunnion remote is 2 pos.
https://www.ridefox.com/family.php?m=bike&family=float
MC356
by MC356
snaxez wrote:
Wed Nov 30, 2022 8:35 am
The 2 position only comes in 165x45 :(
BMC TMR01
Niner Air 9 RDO
snaxez
by snaxez
Yeah, I saw the same now, when you pick trunnion.
It shows:
SIZES (3-position Lever)
Trunnion Metric Sizes 165 x 40 / 165 x 42.5 / 165 x 45 / 185 x 50 / 185 x 52.5 / 185 x 55
SIZES (2-position Remote)
Trunnion Metric Sizes 165 x 45
I would assume you could use that 165 x 45 and add a spacer.
MC356
by MC356
I looked into adding a spacer and the shops I talked to said it will work...
So if I get a 165x45 fox DPS and put a 5mm travel spacer on it, it will into a 165x40 shock. Anyone does this before?
BMC TMR01
Niner Air 9 RDO
