Yes, Light bike much more transparency on parts imformation/value. Good to know how they run business, a bit conservative but good not to put weight on crazy annoying advertising....TobinHatesYou wrote: ↑Thu Dec 01, 2022 8:33 am
If a lot of people like them that's great.
But...
Lun Hyper D45
46mm/54mm depth
21mm internal
27.6mm external
carbon spokes
OE hubs
hybrid ceramic bearings
~1421g
US$1300
vs
Light Bicycle AR55
55mm depth
21mm internal
30mm external
Sapim CX-Ray spokes
DT Swiss 240 EXP hubs
TPI steel bearings (technical partners with NTN)
~1368g
$1247
or
Light Bicycle WR50
50mm depth
25mm internal
32mm external
Sapim CX-Ray spokes
~1368g
$1247
The LB wheels are lighter, cheaper and wider. They come with DT Swiss hubs vs proprietary OE hubs. They don't rely on carbon spokes to achieve their light weight. The front wheel is deeper on both Light Bicycle wheelsets, which is of key importance for aerodynamic efficiency.
Lightbicycle Vs Lun Wheels Vs Elite drive
Forum rules
Anyway if wheel manufacturers want to use carbon spokes, they need to make use of carbon’s advantages by using fewer, stronger, larger surface area spokes with narrower bracing a la the old Spinergy Rev X wheels. It is almost pointless to build a conventional spoke out of carbon.
Agree. I think you are seeing lower spoke count in wheels that come standard with carbon spokes (e.g. the Winspace Hyper and Elite Drive). I recall looking at a weight chart showing spoke options on one of the manufacturer sites and there wasn't much if any weight savings just switching to a carbon spoke over the CX-Ray.
MrStop wrote: ↑Thu Dec 01, 2022 6:43 pmAgree. I think you are seeing lower spoke count in wheels that come standard with carbon spokes (e.g. the Winspace Hyper and Elite Drive). I recall looking at a weight chart showing spoke options on one of the manufacturer sites and there wasn't much if any weight savings just switching to a carbon spoke over the CX-Ray.
Yeah, but I literally mean going all the way down to 6-12 paired, highly bladed integral spokes, not 18-21 in a conventional 2x pattern.
The LB you mentioned are all flyweight so rated to 90kg instead of 135kg, also you have to include shipping so it's around 1370$. Hyper SE come at 900$ shipped with the discount code and are both 50mm at 1470g and have steel bearings. I don't get the diffrent profile on the new hypers. Also I'd rather have carbon spokes which are far far stiffer and a heavier rim which is strongerTobinHatesYou wrote: ↑Thu Dec 01, 2022 8:33 am
But...
Lun Hyper D45
46mm/54mm depth
21mm internal
27.6mm external
carbon spokes
OE hubs
~1421g
US$1300
vs
Light Bicycle AR55
55mm depth
21mm internal
30mm external
Sapim CX-Ray spokes
~1368g
$1247
or
Light Bicycle WR50
50mm depth
25mm internal
32mm external
Sapim CX-Ray spokes
~1368g
$1247
Edopizzo wrote: ↑Sat Dec 03, 2022 12:18 pm
What’s the max rider weight rating on the Hyper 2023? Also you can avoid customs/import duties with Light Bicycle’s shipping options.
Spoke stiffness is not necessarily a virtue. I don’t want a vertically stiff ride, especially at the local road races.
enn, LB also offered BF discount so the price difference is not the essence. I was told recently by a manufacturing insider and understand the "non proprietary parts" is much more complicate than it literally is. The unlimited specs (They call it 'Full Custom') Light Bicycle offers does not make use of mass production effect, which ought to shape to your unique demand that is pretty difficult for manufacturers however. Quite good for us, and just need to ask them for what you wantEdopizzo wrote: ↑Sat Dec 03, 2022 12:18 pmThe LB you mentioned are all flyweight so rated to 90kg instead of 135kg, also you have to include shipping so it's around 1370$. Hyper SE come at 900$ shipped with the discount code and are both 50mm at 1470g and have steel bearings. I don't get the diffrent profile on the new hypers. Also I'd rather have carbon spokes which are far far stiffer and a heavier rim which is strongerTobinHatesYou wrote: ↑Thu Dec 01, 2022 8:33 am
But...
Lun Hyper D45
46mm/54mm depth
21mm internal
27.6mm external
carbon spokes
OE hubs
~1421g
US$1300
vs
Light Bicycle AR55
55mm depth
21mm internal
30mm external
Sapim CX-Ray spokes
~1368g
$1247
or
Light Bicycle WR50
50mm depth
25mm internal
32mm external
Sapim CX-Ray spokes
~1368g
$1247
elite wheels Drive
the best weight , price? 1/3 cadex price , same 50mm, same limit kgs 130, same ceramics, same all!!!!!
this weigth is includes tubeless tape + nozzle
dam it!!!!
dam it!!!!
But wheel stiffness is nowhere near (a good 15-20% difference) with CX-ray spokes. The carbon spokes weight is just a good side effect but their main benefit is really stiffness (unless you are Hunt and play the weight gain and keep a low stiffnessTobinHatesYou wrote: ↑Thu Dec 01, 2022 8:33 amBut...
Lun Hyper D45
46mm/54mm depth
21mm internal
27.6mm external
carbon spokes
OE hubs
~1421g
US$1300
vs
Light Bicycle AR55
55mm depth
21mm internal
30mm external
Sapim CX-Ray spokes
~1368g
$1247
or
Light Bicycle WR50
50mm depth
25mm internal
32mm external
Sapim CX-Ray spokes
~1368g
$1247
Lun Disc hubs appear quite heavy cause the rim brake are just north 1300g in 50mm.
To me the only 2 reasons to go LB is if you really need to go 28mm+ tires and if you want hub that require less maintenance (I am still a bit skeptical on Lun free-hub water tightness)
C36 wrote: ↑Fri Dec 09, 2022 10:05 am
But wheel stiffness is nowhere near (a good 15-20% difference) with CX-ray spokes. The carbon spokes weight is just a good side effect but their main benefit is really stiffness (unless you are Hunt and play the weight gain and keep a low stiffness).
Maybe Jakobsen or Groenewegen need a stiffer wheel, but certainly not most of us. I actually want a more vertically compliant wheel.
