Dura Ace BB/GRX 810 crankset compatibility
liam7020
by liam7020
I need to replace the BB on my cross bike. Does anyone know if the Dura Ace SM-BB9100 bottom bracket is compatible with the GRX 810 1x crankset? Thanks.
Tarmac SL6 & Campag Record EPS https://weightweenies.starbike.com/foru ... 0&t=153968
FTPWhor
by FTPWhor
Yes, there should be no issues.
liam7020
by liam7020
Thanks for that. I managed to find the Shimano compatibility chart and I think you're quite right. For some reason best known to Shimano, the OD of the notched cup is different between Ultegra and DA, so it looks like I'll need yet another bottom bracket tool! Cheers.
anzi
by anzi
If my memory is to be trusted Dura-Ace bottom bracket comes with an adapter so you can use a standard bb tool.
liam7020
by liam7020
Ok, thanks for that info. I'll save my pennies until I receive the bb before buying the tool.
