Thinking about getting into very light MTB. No idea where to begin
There is a local facility near me that has a course and rents bikes out so I'm going to go there first to see if I even like it
If so I know I will prob start with a hardtail but I know nothing about good brands, systems etc. Been watching videos and reading but still kind of confused. My main goal with MTB is to get back to just riding for fun as road biking is very serious business.
Of course this being a WW forum I am curious about what a reasonable weight is for an MTB, say on a budget of $1000. I'm not squeamish about Chinese stuff so I'd have no problem with another AE build.
Budget 1000 usd for Mtb...
Expect 15kg hardtail bike with lowest spec kit, supermarket level bike which is going to demotivate you from mountain biking very quickly.
I think acceptable hardtail bike is for example scalpel HT or trek procaliber.
With prices around 2500 usd and up. That would still be a low spec hardtail bike with weight 11 kg, but at least acceptable fork and carbon frame.
Good weight for hardtail bike is below 8.5kg and under 10kg for full suspension.
S-Works SL7 Dusty Blue 56cm @ Sram RED AXS Quarq, ZIPP 404 Firecrest, MCFK Aero Handlebar, PD-R9100 (7.2kg)
S-Works Epic 2022 Gloss Fluid L @ Sram XX1 AXS Quarq & Berg Ratheberg & BikeYoke Divine SL, Xpedo M-Force 8 (9.9kg)
- eucalyptus
1000 bucks?
Honestly, I don't think lightweight is included in that vocabulary among $1000.
Just a good set of tires will set you back at least 100 Euro.
Going to an LBS, the cheapest low-end bikes with the most basic stuff is starting around $800, hence in this range weight is the least important factor and more about making it possible to put a bike together which is rideable for most beginners/entry level
Not trying to be mean or harsh, I worked for some in a bikeshop and sadly this price range is very common but in reality you don't get much for the money
You can't get good bike at that price.
A good suspension fork cost $400 - $1000, assume you found a super deal at $200 then.
A decent wheel cost at least $150 a set (usual price $400). Then assume a super cheap set of mtb tires at $20 each (usually, they are $36-80 each)
Let say, stem $20, bar $30, Grip $10,
And you are left with $550 for the whole frame + hydraulic brakes + {crank, chain cassette, shifter and rear derailleur} +and possibly rear shock if you go for full suspension, (which you wouldn't).
Brands to consider for budget build
fork: SR Suntour have many cheap forks. Some are good. The problem is, they have so many forks that the line up is confusing and hard to select which one to buy.
Tires: American classic
Stem: Kalloy Uno
Bar: Protaper. You can get carbon bar at $43 from a reputable brand under Hayes.
https://hayesbicycle.com/products/prota ... lebar-720w
Groupset: Shimano Deore, Microshift
Brakes: Shimano Deore, TRP
Stem: Kalloy Uno
Wow, a set of fully adjustable forks for my motorcycle was cheaper than $400 including a rebuild. I'm going to rent a bike at at local trail to see if I even like it.
Is carbon a must for MTB frames? From what I've seen more expensive frames are alloy. Metal seems more logical given the potential for impacts as well.
No, it’s not necessary. But the more expensive frames, unless you’re talking about bespoke/small batch/custom, are usually carbon fiber. If a company makes an aluminum and carbon versions of the same frame, the carbon frame is always more expensive.cheapvega wrote:Wow, a set of fully adjustable forks for my motorcycle was cheaper than $400 including a rebuild. I'm going to rent a bike at at local trail to see if I even like it.
And they're probably pretty shit compared to a pro class race fork. Which is what you are comparing to with $1000+ MTB forks.
You can get yourself a fork for $89. If you want. (e.g. Ohlins RXF 48S is around €3500 and doesn't seem to include anything other than legs...)
Lightweight metal is (if anything) more fragile at similar weights to carbon. Quite easy to provide protection if you're really going to be going for it, or buy a more suitable bike, with a more robust frame.
any light mtb carbon frames not expensive?
Well a friend of mine lent me his Top Fuel...8?.... and I went to a local trail with another friend. It was a lot of fun. Now what? I def want a trail bike. I've had nothing but good experiences with my Dengfu so I'm thinking about going full Chinese for the MTB (well maybe outside of the suspension).
