Best HR strap
TidyDinosaur
by TidyDinosaur
TidyDinosaur wrote:
Tue Oct 17, 2023 8:46 am
T65 wrote:
Fri Sep 15, 2023 6:59 pm
I just cannot imagine people get multiple years of use out of the strap. I use Garmin and the sensor almost lasts forever on the same battery. But the strap goes bananas within a year. I always rinse it after workouts. Replaced Garmin by Polar soft strap but the same experience. I'm now using a Magene strap that feels really cheap and costs even less. Will see how long that one survives. But I hate throwing non-recyclable stuff in the bin...
Same here, can't seem to get the H10 straps to last a year... Kind of expensive straps like that :(
Little follow up: I started wearing my strap in the shower after every training and stopped putting it in the washing machine. It had been much more reliable since...
pushpush
by pushpush
TidyDinosaur wrote:
Fri Dec 08, 2023 9:48 am
What HR zone do you shower? hahahah
I always rinse mine off in fresh water after training. It never even occurred to me to put it in the washer.
TidyDinosaur
by TidyDinosaur
pushpush wrote:
Fri Dec 08, 2023 9:30 pm
I do remove the sensor before showering :)
In the past I would rinse the strap every 3-4 trainings and put it in the washing machine once every six weeks or so. After about a year the strap started to lose connection... Since I have started to wear the strap in thwe shower the problem has diasppeared (it is also fall here so most of the training is done indoor these days)
BdaGhisallo
by BdaGhisallo
TidyDinosaur wrote:
Sat Dec 09, 2023 9:24 am
My HR belt goes in the washing machine with all my riding clothes (helmet pads included) after every use. I don't have any issues with connectivity or longevity.
Using a Polar H10 with Polar belts.
hendrik
by hendrik
I recently got myself a cheap Coospo and so far it is just as good as my Garmin Dual at half the price. Let's see if it lasts!
naavt
by naavt
MrCurrieinahurry wrote:
Thu Dec 07, 2023 5:57 pm
I'd want a fully sealed (so it's actually waterproof) wireless rechargeable unit which shows battery life and signal strength on my wahoo head unit and screen for zwift.
Basso Diamante rim Campagnolo EPS 12 Bora WTO 60's
I suspect that such a tiny device with wireless rechargeable batteries will need to be charged often.
I'm a Whoop user and the charging system is a clever one (you don't need to take it off your wrist), but even then, recharging it every couple of days is a PITA.
For that reason I'll happily stay with a coin cell for now.
voicycle
by voicycle
I used to put my Tickr V1 strap in the washing machine once a week with other kit (pod removed) with great results. That was the second strap I'd bought for it and it outlived the pod (after never washing the first strap until it corroded and fell apart because I didn't know any better).
When I switched to Garmin HRM Pro I was disappointed to discover I couldn't remove the pod to wash the strap. I messaged DCRainmaker about it on twitter and he said he just wears his in the shower. Pretty sure I've seen him advise the same elsewhere since, so I guess this is now 'the way'.
I usually spend 20-60 minutes doing stretching and strength after my bike session though, so I've taken to just removing the HRM and flinging it on the shower floor. Then once I'm ready to shower it gets a good rinse whilst the water warms up. When I get in the shower I just give it a little wipe down under the shower head and then hang over the shower door to dry.
Biggest shame of it all is I got the HRM Pro because I started running a bit as part of my training and it can serve as a running power meter in conjunction with a Garmin watch. The power numbers are basically useless though - they bear no correlation to my bike power so I'm just as well ignoring that data. I'm not doing interval training or anything - literally just running off the bike for 15 minutes once a week to get some impact into my routine - but I wanted a more accurate TSS estimate in order to track overall training load better. Some of the other running dynamics data might be interesting to look at someday, but ultimately I'm just wasting the useful life of a more expensive device when I don't actually need anything more than a reliable BPM data field on my bike computer.
I think I actually preferred my Tickr V1 setup with washable/replaceable strap. I'd grab another Wahoo as my spare/daily driver but DCR doesn't like V2's reliability, which is a shame. H10 is just a bit too expensive to be a secondary HRM, otherwise I'd grab one of those to use for everything except the days where I'm running.
Ritsuke
by Ritsuke
The strap lasted for 2 years but now it's done. Readings start ok but then drop to +/- 90 bpm and later drop to around 50.
TribesMan
by TribesMan
Bought Xoss X2 pro in AliExpress for 25€.
Works fine, very small pod, has on-board storage and is rechargable, so no more coin batteries...
Will see how it works long term, but so far I'm very happy with it.
bmrk
by bmrk
I've been using the magene H603 for the past 2 years almost daily, works perfectly and shows no signs of usage. Just replaced the battery a month ago.
Savon
by Savon
Ritsuke wrote:
Tue Jul 09, 2024 1:43 pm
Which strap?
My Polar H10 has suddenly become very slow to respond, it goes from 80 to 160 bpm in 3 seconds while I've been pushing myself for 1 minute, same thing in the other direction.
It is 3 years old, with approximately 600 activities logged. I always rinse it with water and a bit of soap, and I clean the pod with 70% alcohol using a tissue. I don't see any signs of wear on the strap.
I don't know what to do, replace the strap (43 euros for me on polar.com), buy something else (like magene H603 for 31 euros).
vinc
by vinc
Which strap?
Just replace the strap… at least that’s what I would do :)
Savon
by Savon
I bought the Magene H603 and after seven activities, including one with my Polar H10. I have a slight delay with the H10 (about 1 second or maybe 1/2s), but it might have been because it was connected via Bluetooth to a Polar watch, whereas the Magene was connected via ANT to my Wahoo Bolt.
However, the strap feels really cheap compared to the Polar strap. It looks like the Wahoo TICKR strap, but it doesn't slip, and after 7 days, I got used to it.
Let's see how long I can go without any problems to determine if it was a good deal. Also, I think I’ll look for a good deal on an H10 strap, maybe during Black Friday or something like that.
ms6073
by ms6073
Savon wrote:
Tue Jul 30, 2024 7:07 am
I bought one from Amazon (US) a week or so back and thus far, compared to my 2-year old Wahoo Tickr, have found it to be a bit problematic in terms of reconnecting when riding indoors with Rouvy. Question is how to 'wake up' the sensor if you go out of range of the device it is connected to? When I first snap the strap to the sensor, a red LED blinks on the sensor and it easily connects/pairs with the laptop, but I cannot figure out what is the process for 'waking' the sensor back up after moving out of range of the connected device - my Wahoo Tickr never has an issue with this scenario. As a workaround, I connect it to the trainer app, then leave it in the room with the trainer while I finish getting ready.
- Michael
bmrk
by bmrk
ms6073 wrote:
Tue Jul 30, 2024 5:28 pm
I bought one from Amazon (US) a week or so back and thus far, compared to my 2-year old Wahoo Tickr, have found it to be a bit problematic in terms of reconnecting when riding indoors with Rouvy. Question is how to 'wake up' the sensor back up if you go out of range of the connected device? When I first snap the strap to the sensor, a red LED blinks on the sensor and it easily connects/pairs with the laptop, but I cannot figure out what is the process for 'waking' the sensor back up after moving out of range of the connected device - my Wahoo Tickr never has an issue with this scenario.
This might be an software or hardware problem other than the H603. I have the same strap and never faced connectivity issues with over 2yrs of daily usage. Also my strap is still like new.
