Best HR strap
Had multiple Wahoo straps break on me, same goes for my cycling buddies. I don't understand how a brand that big throws their name up for grabs for something as simple as a HR strap. I definitely steer more towards Garmin/Tacx products who have their own faults, but never ran into much problems with them (plus they are somewhat local and preferred, making it a lot easier to replace when something goes wrong).
Nope but I'll use the advised type of battery anyway.TobinHatesYou wrote: ↑Thu Sep 01, 2022 2:06 amHmmmmm...
I stuck a CR2032 in the H10 and it "fits." Can you tell which one has the 2025 and which one has the 2032?
Road // 2021 S-Works Tarmac SL7 | Shimano Dura-Ace Di2 | Roval Rapide CLX
TT // 2022 S-Works Shiv TT | SRAM Red etap AXS | Roval Disc - Rapide CLX
Retired // 2019 Specialized Allez Sprint Red Hook | SRAM Red Etap | FFWD F6R
Another vote for the Polar H10. Solid performance and long history in the sport and HR monitors.
In the early 2000s I had Polar unit that was made in Finland and have been committed ever since. I’d love it see Polar develop a better bike computer that would compete with Garmin and Wahoo.
Seeing their track record with pretty much any hardware it's no surprise that the HR strap matches almost everything else they produce in quality.Ypuh wrote: ↑Sun Sep 04, 2022 4:50 pmHad multiple Wahoo straps break on me, same goes for my cycling buddies. I don't understand how a brand that big throws their name up for grabs for something as simple as a HR strap. I definitely steer more towards Garmin/Tacx products who have their own faults, but never ran into much problems with them (plus they are somewhat local and preferred, making it a lot easier to replace when something goes wrong).
What are peoples thoughts on the Polar H9 or the Garmin HRM-Dual? Is there any reason to go with the Polar H10 over these two cheaper alternitives?
The Polar's using CR2025 batteries is somewhat of a turn off as I already keep CR2032's on hand for other things.
2015 Wilier Zero.7 Rim - 6.37kg
2017 Trek Domane SLR-7 Disc - 8.36kg
2020 Trek Emonda SLR-7 Disc - 6.86kg
The HRM Dual is functional, but the 4 Phillips #00 screws are sometimes a pain to back out. On occasion I’ve had to let some WD40 soak into the threads to swap batteries.
The HRM Pro Plus is took less but the sensor is integrated into the strap.
I go through at least 2 batteries every year with the Polar H10 and at least 1 battery per year with CR2032 based HRMs. I rode 950 hours in 2021.
I'm not sure WTF is going on with my H10 but the last battery only lasted 3 weeks
Unfortunately this seems to be a not-uncommon issue. Your current battery might last less than a week. It seems some of the surface components can permanently short after some water ingress… the only fix is to send it in for repair/replacement.tonytourist wrote: ↑Thu Sep 29, 2022 11:49 pmI'm not sure WTF is going on with my H10 but the last battery only lasted 3 weeks![]()
Everything seemed dry when I swapped it, we'll see if maybe I have had some bunk Duracell batteries.
If not, I'll grab the Garmin and send this one in.
The HRM1G? Still what I consider the reliability benchmark, after all those years.
But we are on weightweenies, the H10 is 15g lighter. Even with the 2032 "monster battery". 30g lighter on a cardiosport FF5 strap
I've had the same issue with my Tickr strap sensors starting to peel after a year or two. I recently discovered you can buy replacement straps on AliExpress for $5 that are supposedly compatible. I think they are the same aftermarket straps that are going for $20 on Amazon with many reviews indicating they work. I've got one on order.
Garmin HRM Pro has been working very well. First I was sceptial because the pod is integrated into the strap, but it has been 100% every time.
Changed battery once, no problems (you will read horror stories about this online)
The HRM Pro Plus has tool-less battery swaps
These straps can connect to the Garmin app and receive firmware updates
Giant TCR Adv Pro Disc '17 · BH Lynx Race Evo '19 · Seraph GR029 '21 · Canyon Inflite AL '14
- Juanmoretime
- Administrator
I've been using this right here.Cheap,works and it's lasted over a year!
https://www.amazon.com/CooSpo-H6-Monito ... 81&sr=8-19
Interesting that there are so many issues with the Wahoo straps. Mine is still working 5 years later. I like the clicking nature of the strap into the sensor, was never very fond of the style Garmin uses with the slide of thr strap onto the plastic buckle.
Vamoots RSL Disc - 7.6kg
Tarmac SL7 Pro - 7.9kg
