Best HR strap
Moltobene
by Moltobene
The actual straps themselves are a consumable and should be replaced regularly, so it's not a problem if they only last a year or so. The problem with the Tickr is that the sensor itself often lasts only about a year, while the Polar ones last way longer as they should. If they start behaving erratically, it's usually down to the battery (which drains faster on the Polar than on the Tickr in my experience, but it also uses a smaller battery).
My current H9 is now going 2,5 years and no signs of wear, although I have seen H7s in the lab last way longer even with heavy use (and cleaning). Another advantage of the Polar sensors is the HRV accuracy via bluetooth and this didn't work for me with the Tickr.
jfl
by jfl
My cheap Decathlon HR strap has been running reliably for several years.
gbrnole
by gbrnole
my H9 works great. as noted above the biggest downside is battery life but i find that to be because the HR unit still consumes some power if you only disconnect one side of the strap.
TobinHatesYou
by TobinHatesYou
It's best practice to disconnect the sensor and rinse the strap after every ride anyway. I usually fully handwash my strap with handsoap after each ride.
C36
by C36
Moltobene wrote:The actual straps themselves are a consumable and should be replaced regularly, so it's not a problem if they only last a year
That’s new… when did it turn into a tire or a chain? It should last for years, I have a polar (unknown reference) for 6 years and a Bontrager in my mountain house for 3 years, the only one that failed within 18 months was a wahoo.
Moltobene
by Moltobene
Yes, it should last for years, but it isn't uncommon for the strap to fail. Seams and stitchings can fail, closures break, electrodes fail or the glue doesn't hold them on the strap anymore. There's a reason straps are being sold as a relatively cheap replacement. The problem with the tickr however isn't that the strap fails, but the sensor (although I also heard that the strap fails relatively quickly, as you've described as well).
Spurdo
by Spurdo
My Tickr is just fine after 5 years of use, any recurring errors have been fixed by replacing the strap and/or moistening chest+strap
TobinHatesYou
by TobinHatesYou
Spurdo wrote:
Thu Jul 14, 2022 10:51 pm
My Polar H10 "pro soft strap" is handwashed after every single ride and machine washed once a week. It still works just fine. Straps shouldn't stop working just because.
Spurdo
by Spurdo
TobinHatesYou wrote:
Fri Jul 15, 2022 6:55 am
Sure I'd like those to last longer but I dont find on average one strap per season to be excessive when I get some 600-700 hours of use from it.
JayOJonson
by JayOJonson
The h10 has been spot on for me, highly recommend it.
CrankAddictsRich
by CrankAddictsRich
I picked up a Polar H10 yesterday based on the posts in this thread.... super happy with it after the first day of use. The strap is very comfortable and stays in place. The Wahoo Tickr strap I had always wanted to fold on itself or slide down.
TobinHatesYou
by TobinHatesYou
CrankAddictsRich wrote:
Sun Jul 31, 2022 12:01 am
It's great, though have spare CR2025s handy. The H10's battery life is roughly half that of everything else on the market using deeper CR2032s.
Ritsuke
by Ritsuke
Mon Aug 01, 2022 5:57 am
Thanks for the heads up. I didn't know about the CR2025 but luckily I have some laying around from the Powerbox days.
- Sig
TobinHatesYou
by TobinHatesYou
Ritsuke wrote:
Fri Aug 19, 2022 5:47 pm
Hmmmmm...
I stuck a CR2032 in the H10 and it "fits." Can you tell which one has the 2025 and which one has the 2032?
