I mean gravel wheel,If so it would be great,I am interested in what 1100g wheelset are,could you give us a wheelset photo or link,ThanksKlaster_1 wrote: ↑Wed Jun 01, 2022 11:35 amNot sure about "very light", my 45mm deep wheels are 1100g and cost only 250USD more than Elites.woodzyz wrote: ↑Wed Jun 01, 2022 9:37 amElite has the first carbon spoke wheelset coming out,total 1300g for 45mm deep rim,it is very light even for climbing
https://www.elite-wheels.com/news/new-a ... -available
Carbon spokes in 2022
Forum rules
Hunt Carbon 4454
"So, I have several hundreds of kilometres on HUNT 4454 UD Carbon and I am impressed...
- Very stiff on every way,
- but also very comfortable in combination with tubeless tyres Schwalbe Pro One TLE (front 25 + rear 28 mm),
- no creaking, carbon spokes are not touching anywhere,
- the rear hub is very very loud, louder than e. g. DT 350 (with ratchet system 36T) / Roval CLX 50 / Roval CL 50,
- H+ lifetime warranty is a big plus."
viewtopic.php?t=164747
Another thousands of kilometres (I have several bikes) and I can confirm all, very satisfied with them.
Me in combination of 4454...wheelie wrote: ↑Fri Oct 22, 2021 5:13 pmhttps://eu.huntbikewheels.com/collectio ... c-wheelset
Anyone already tested these 44 mm wheels and have opinion about real weight & reliability?
Tnx!
My wheels are getting built by Lightbicycle with carbon spokes using dt240s is there going to be a problem I see a lot of people say u have to use a special hub but they don’t seem to mind. There’s even a blurb about it on the sitestevesbike wrote: ↑Wed Jun 01, 2022 6:43 pmI don't see how buying some carbon spokes would be worthwhile. All I've seen require a carbon spoke-specific hub and I haven't seen any aftermarket ones available. Some of the newer models of wheelsets like the Elites also have offset spoke holes in the rims so the spokes don't contact each other where they overlap in non-radial builds. Abrasion caused by contact at these points has been identified as a potential failure mode, so overall it seems carbon spokes require a complete system.
Many carbon-spoked wheels on the market come with a single hub option, which goes against our Full-Custom nature. A major difficulty in the hub compatibility of a carbon spoke is the slightly wider midsection of the spokes, which can make threading through the holes of most hubs difficult. To solve this, we’ve designed a segmented hub-end construction: by simply unscrewing and re-screwing the spokes to hubs from Bitex, DT Swiss, Carbon-Ti, or any other straight pull brand.
Re LB: the weight difference vs Sapim CX Ray is 20g. Price difference is $200. Potential downside: 1) worse aero performance of the spokes due to being thicker and wider; 2) carbon just breaks and does not bend. Is it really worth it???
Upsides, 1) regain stiffness lost with the spoke count reduction and the Cx-ray structural flexibility, 2) Aero, still to be assessed but as long as the ratio is preserved, impact on rotational drag is not clear, especially under lateral wind. Stiffness and strength also allow to reduce the number of spokes.aeroisnteverything wrote: ↑Wed Nov 23, 2022 12:27 pmRe LB: the weight difference vs Sapim CX Ray is 20g. Price difference is $200. Potential downside: 1) worse aero performance of the spokes due to being thicker and wider; 2) carbon just breaks and does not bend. Is it really worth it???
I heard 9VELO make very good carbon spoke wheels https://www.9velo.com/collections/carbon-spoke. Just refer to their IG for a coupon, you can get a very good price.
C36 wrote: ↑Wed Nov 23, 2022 3:37 pmUpsides, 1) regain stiffness lost with the spoke count reduction and the Cx-ray structural flexibility, 2) Aero, still to be assessed but as long as the ratio is preserved, impact on rotational drag is not clear, especially under lateral wind. Stiffness and strength also allow to reduce the number of spokes.aeroisnteverything wrote: ↑Wed Nov 23, 2022 12:27 pmRe LB: the weight difference vs Sapim CX Ray is 20g. Price difference is $200. Potential downside: 1) worse aero performance of the spokes due to being thicker and wider; 2) carbon just breaks and does not bend. Is it really worth it???
Stronger, stiffer spokes could reduce the reliance on bracing angle and allow for closer spaced hub flanges too. Though at some point you just end up with a Bike-Ahead Biturbo or Black Inc Five instead of using conventional looking spokes.
That's a wheelset not a aerofoil shaped spoke?Oncarbon wrote: ↑Mon Nov 28, 2022 3:02 amI heard 9VELO make very good carbon spoke wheels https://www.9velo.com/collections/carbon-spoke. Just refer to their IG for a coupon, you can get a very good price.
3-5 Spoked wheels do have quite a lot of stiffness problems, or limitation outside TT type of applications, Biturbo, with bigger spokes, won't be very aero (eyballing it here).TobinHatesYou wrote: ↑Mon Nov 28, 2022 4:19 amStronger, stiffer spokes could reduce the reliance on bracing angle and allow for closer spaced hub flanges too. Though at some point you just end up with a Bike-Ahead Biturbo or Black Inc Five instead of using conventional looking spokes.
Spinergy Rev-X were a inbetween case where the blades stiffness allowed a very narrow bracing angle (and on top of my head were extremely aero quite faster than specialized tri-spokes for example), symetrical front and rear-wheels and ultrahigh stiffness (at the cost of a heavy weight).
Closest to us, the Lun Hypers reach 57N/mm on the front wheel. That's less than than the old -heavier- Lw Gen3 with 20 spokes that also have very wide front hub and in the same region than Mavic CCU or Corima MCC. Definitively could reduce the bracing angle, drop 10% stiffness and still be ahead of many popular wheels.
Now, what I haven't seen measured is the impact of brace angle in aero and how impactfull it is on wheel drag.
Edit: just for the sake of being complete... 1995 wind tunel data with narrow-brace-angle Spinergys
http://www.sportsci.org/traintech/aerow ... #zinn#zinn
Very interesting, with standard hubs, e. g. DT Swiss? Please, can you post any pics of whole wheelsets?
- AscentBikes
- in the industry
- Contact:
Hello all,
I wanted to give a little bit of perspective as a wheelbuilder. I own Ascent Bikes, so take what I say from that viewpoint.
Initial foray into Carbon Spokes
My interest in carbon spokes came about after seeing them at the Taipei Bike Show pre-COVID. The weight and stiffness numbers were impressive, but one of the key things that prevented us from adopting carbon spokes was that they were not compatible with standard hubs. A bespoke hub would be required, and we did not want to compromise user choice in this matter.
Polaris 69mm and the recall
It was around mid-2021 that we found a brand of carbon spokes that were compatible with standard straightpull hubs. These had a spoke head and threaded end bonded to the carbon - they were thin enough to fit through the spoke holes (~1.7x2.3mm). For our Polaris 69mm wheels (released end 2021), our top-end wheels with DT180 hubs were supposed to be made with carbon spokes, in order to reduce the weight of the rim even further.
We did the durability testing, including sending the wheels to Belgium for fatigue bump and sprint testing - and the test wheels passed. However, as history would have it, the spokes faced delamination issues from the heads/threads in production and we performed a global recall of the Polaris 69 DT180. Winspace and Elite use proprietary hubs with taper-lock nipples, so they do not have this issue. However, the spokes used by EIE seem susceptible to the same kind of failure mode.
Why we are currently sticking to CX Rays
That being said, even if the delamination issues are solved, there are a couple of reasons why we believe in sticking to CX Rays.
1) Excessive stiffness of the spokes (esp the wide, bladed carbon spokes) means that users tend to lower their tire pressure to compensate - this increases rolling resistance, and below a certain point, you compromise cornering control. Having slightly stretchier CX Rays allows tire pressure to be raised a little, for better rolling resistance.
2) Ability to get a replacement in the field - Break a spoke while traveling, and most shops would not have a replacement available.
3) Ease of maintenance - Most of the wheels with carbon spokes today are internally adjusted (you have to remove the tire, sealant, rim tape etc to true the wheel), so it's very hard to make quick repairs. Some rims tend to deform a little when used tubeless due to the large amount of force, and having an internally-adjusted setup makes it impossible to dial the wheel in while the tire is mounted.
4) Choice of any hub - You can build with whatever hub you want. It'll work.
I think the best places to use carbon spokes would be smooth roads, and where local maintenance and support is readily available.
However, as we are positioning Polaris as a all-road, all-condition wheelset, it makes more sense for us to stick to reliable CX Rays in this case.
Hope this perspective helps!
QX
Founder
Ascent Bikes
QX
Founder
Ascent Bikes
