New Michelin Power Cup Tubeless: GP5K S TR competitor
Forum rules
Yoln
by Yoln
Not sure how legit is the "Independent Testing" by Wheel Energy, but comparing to GP5K S TR:
- same weight
- 0.1W better rolling resistance
- similar puncture protection
- and apparently a much better cornering grip
Could this be the new king of race/crits?
https://www.bikeradar.com/news/michelin-power-cup/
TobinHatesYou
by TobinHatesYou
I only see results for the clincher + standard weight butyl tube in the BikeRadar link. Let's see results for the tubeless version...
The king of crits is the Corsa Speed.
Yoln
by Yoln
TobinHatesYou wrote:
Thu Mar 10, 2022 4:06 am
I don't know where you race crust but here in the northeast your puncture probability with corsa speed is probably >50% per race. I love them, but only for TTs
TobinHatesYou
by TobinHatesYou
Yoln wrote:
Thu Mar 10, 2022 4:59 am
I assume you're saying "probably" because you've never tried it. I have, and the roads I race on are almost certain worse than anything in the NE. Pump your Corsa Speeds up so you don't damage the sidewalls running over cracks and trust the sealant plug punctures caused by other detritus. Though yes, if you want a little bit more piece of mind, the GP5K S TR are also fast... almost all tires are effectively "equal" in terms of dry grip.
Here is part of the Merced Crit course which was just run last week. Advance through a few paces to see the road surface get worse and worse.
https://goo.gl/maps/Nw4d4ZS4uHA1F2yk6
e: We also have Botts Dots and these...
Attermann
by Attermann
Four posts in, and already a deroute from the topic.
TobinHatesYou
by TobinHatesYou
Attermann wrote:
Thu Mar 10, 2022 9:11 am
Main takeaways vs GP5K S TR. .1W really doesn't really matter. Weight is the same. Puncture protection is the same. Cornering grip is good enough on any tire in the dry.
Why doesn't .1W matter? Because the test is done at very specific settings. Because wear level, temperature, road quality, etc. can swing the pendulum back and forth. Because only the clinchers were tested...with thicc butyl tubes. Who's caring about .1W and also using ~100g butyl tubes? Literally no one.
Buy whichever tire of the two is on sale and less expensive at any given moment.
chuingbeans
by chuingbeans
If these inflate as “oversized” as Vittoria Corsas, I’m in.
TobinHatesYou
by TobinHatesYou
chuingbeans wrote:
Thu Mar 10, 2022 9:41 am
The 20g weight reduction from the Power Road TLR strongly hints at the tires being narrower than those.
robeambro
by robeambro
A tyre which is launched with already an "independent test" showing that it is 0.1w faster than the main competitor.. I'll remain skeptical - let's see if BRR confirms it.
That said, the Power Road TLR is the very only tyre that I had to return as I was not able to fit them, they were both gnarly to mount and then they just wouldn't pop onto the rim. I've had a fair share of GP5k's, but those were far more of a pain. Truly hope these would be easier.
FlatlandClimber
by FlatlandClimber
Has anyone proposed it to BRR?
I have used up my vote on the new Pathfinders 😅.
Cervelo P5 Disc (2021) 9.1kg
S-Works SL8 (2023) 6.3kg
TwiggyForest
by TwiggyForest
FlatlandClimber wrote:
Thu Mar 10, 2022 10:28 am
The 25c clincher and TLR are already there for voting. I already voted for the American Classic Timekeepers for the month.
dmccombs
by dmccombs
I wonder if the 25mm vesion of the Power Cup will be approved for use on 23mm inernal width rims. The 5000 S TR and many other tires are not. Many f us with 23mm internal width rims will be looking for this info.
Elmersen
by Elmersen
Now that the new ERTRO allows for 25mm on 23c, isn't a bit strange that some manufacturers don't? Will we ses a change for GP5000 S TR?
jfranci3
by jfranci3
The test result indicates the used Wheel Energy https://www.velonews.com/gear/road-gear ... esting-it/ Smooth roller and higher pressures, so the numbers will be more favorable to tires with more durable sidewalls. The bumpy rollers and lower pressures highlight more compliant sidewalls.
Looks like this is power road, with a TL bead and less rubber . In any case, the numbers are inline with their current offerings. I assume they are just reducing SKU count, sacrificing longgevity, and making their tires hookless OK.
Aeo
by Aeo
If they help to put pressure on the Continental Grand Prix 5000 TR prices, that is a good thing. They are still at 70€ :roll:
Giant TCR Adv Pro Disc '17 · BH Lynx Race Evo '19 · Seraph GR029 '21 · Canyon Inflite AL '14
