new frame rumors for 2023?
StiffWeenies
by StiffWeenies
ODC wrote:
Mon May 23, 2022 10:24 am
StiffWeenies wrote:
Mon May 23, 2022 8:54 am
V4Rs?
This almost like a Tarmac SL7...
Where is the time that most frames had there own identity. These days almost all bikes look the same.
Some frames are just more industry defining than others. Like how the SystemSix is informing aero bike design even today. You can find traces of Cannondale lineage at the headtube downtube junctions of many newer bikes like the Ostro, Orca Aero, ZX-1 EVO, Ribble Ultra, Workswell WCB-R-369, etc.
StiffWeenies
by StiffWeenies
C36 wrote:
Mon May 23, 2022 10:38 am
It was expected to provide him a “better” frame. V3rs is around 230W as per Tour tests, that is roughly 20 W above an SL7 and probably 10 W slower than a 2016 SSE2 fully equipped with modern components.
From this picture, tube dimensions are relatively thin compared to other pro tour bikes. Only the sl7 seems to play in this category.
I believe "watt sinkhole" was the verbiage used by Tour to describe the V3Rs
thefox
by thefox
New Canyon Ultimate spotted. Not the best picture. It looks like that the ultimate won´t change a lot.
Lina
by Lina
And if you went back 40 years all the bikes looked even more the same. This magical time when bikes from different manufacturers looked different was a very short time between when non lugged carbon became common until everyone realized that aero matters. And even then there's more differences between them than there was when everyone was riding steel.
micky
by micky
V4Rs?
As mentioned from others;
-rear higher seat stays junction with an "aero shape"
-top tube with a more detailed shape near head tube
-using same headset as C68 with Ceramicspeed top cap
and what look like a new more aero shaped seatspost?
Looks larger than the one used in actual models.
henau212
by henau212
thefox wrote:
Mon May 23, 2022 11:24 am
Looks interessing. Kinda hard to tell from the angle, but seatpost looks like an aero shaped one. Also the cockpit seems to be the Aeroad one since it is pretty small in diameter (was hoping for am easier solution). Interesting that they didn't follow the dropped seatstay trend..
C36
by C36
That’s a bit severe, the vr3 is in the ballpark of the TCR, R5, Emonda and scott addict. This being said that still significant compared to Pinarello F, aeroad, sl7 or Filante.
Aeo
by Aeo
Giant TCR Adv Pro Disc '17 · BH Lynx Race Evo '19 · Seraph GR029 '21 · Canyon Inflite AL '14
GaBa
by GaBa
And what are those Campagnolo wheels? Also seem new with lacing different than G3, used on all Boras WTO.
pmprego
by pmprego
micky wrote:
Mon May 23, 2022 12:27 pm
V4Rs?
This is something I expect every high-end bike to follow along. If this really makes the headset bearing last a lifetime, it's a nice investment in a time where cables are all hidden in the headtube.
They will also have to make it lighter somehow. If not the frame then the fork of the small parts like pinarello did.
usr
by usr
Lina wrote:
Mon May 23, 2022 11:30 am
The glorious era of form-defies-function
(I didn't consider those designs glorious at all, but apparently buyers were quite happy)
teslapilot
by teslapilot
GaBa wrote:
Mon May 23, 2022 3:12 pm
https://cyclingtips.com/2022/05/spotted ... blockhaus/
GaBa
by GaBa
Ah, saw this article but did not make the connection - still connecting regular lacing with Campagnolo's Levante and none other. Thanks! :)
Sace
by Sace
Is it just me or does it look like there is a screw on the seattube ? Interesting if that is the seatclamp.
Conradsleight
by Conradsleight
pmprego wrote:
Mon May 23, 2022 4:23 pm
V4Rs?
Factor has been doing this well before colnago. Since 2020 with the Ostro.
