Removing Bridge for bigger tire
alibudia1712
by alibudia1712
Hey, everyone, I'm wondering if it's still safe to remove seat and chainstay bridge on my Ti 27.5 frame so I can fit like 29x2.1 tire? Is there anyone here tried? I've seen newer mtb frames don't have bridge on seat or chainstay. Thanks . mine is Lynskey MT 27.5.
Sent from my Redmi Note 5 using Tapatalk
kode54
by kode54
I had a bridge moved up when I changed my rim-brake Guru to disc and also to accept 35mm tires. Moved a new curved bridge up (no hole for rim brake).
- Factor 02 VAM Disc
- Factor LS Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
- Moots Vamoots Disc RSL Ti
- AX Lightness VIAL evo Rim
02GF74
by 02GF74
That's a difficult one to answer.
Since most frames now are made to use disc brakes, the seat stay bridge had died out.
I've taken at a look at a few Ti frames, some have the bridge, others not, of those that don't, some have additional gussetting near the seat tube.
Asking the manufacturer is likely to not to help as they don't like DIY modifications and it will invalidate the warranty.
As someone suggested, remove the bridge but get a frame builder to add strength back.
Or cut it out and see what happens, I suspect very little in the short term.
alibudia1712
by alibudia1712
recently i've seen a LS gravel frame with no seatstay bridge but still with a chain stay bridge Image. I'll go ask some Ti frame builder i can ask if it possible. I doubt myself to remove the bridges because i think i might also trashing my frame by modifying it Image
alibudia1712
by alibudia1712
just ask John Calletti and found out most his frame build with no bridges. I guess it's gonna be okay if I remove the bridges?
