Best (smoothest) hardtail ? XTC, Epic, other..
fastezzie
by fastezzie
Hi all considering building a new hardtail for next season. I rode a Scott Scale for several years, excellent bike. Looking for lighter weight (Scale frame was 1300g) more tire clearance, longer reach, and a boost/thru-axle hub.
Top two options now are Giant XTC SL and Spec Epic HT. Anyone have ride quality feedback on these bikes? too close to call? any others I should consider?
Prefer something other than Scott for variety sake.
stoney
by stoney
I love my 2020 Epic hardtail...very comfortable. I came from a 2015 Scott Scale so that is my reference point.
ghostinthemachine
by ghostinthemachine
1300g for a scale? Last one i had was 950 ish.
santanacorreia
by santanacorreia
BH hardtail are top notch.
And very, very light.
Enviado do meu SM-G960F através do Tapatalk
fastezzie
by fastezzie
ghostinthemachine wrote:
Thu Oct 21, 2021 11:46 am
Mine is size XL and is the cheaper heavier HMF frame. Weighed with PF bb I think.
ghostinthemachine
OK, the one i had was a M or L and the HMX i think from one of the WC models.
grantrstubbs
by grantrstubbs
I'm interested in this too, problem for us in Australia is not many of the hardtails are available as a frameset.
S-works is the pic for geo and ride I think BUT you are paying a lot for the S Works sticker when the Comp model frame is identical. Probably better to buy the Comp model and strip?
Canyon Exceed is a nice frame too but not available as frame only
Giant XTC looks good but is not available as a frame I don't think
Trek Procaliber probably smoothest wit the ISO Speed Coupler but I recall it being heavy >1300g
viragevitesse
by viragevitesse
I have a 2020 Epic HT, coming off an 2018 XTC before that. The Epic was a hell of an upgrade but could also be a combination of the higher-end build spec and lighter bike weight, but it just felt so much snappier, racier and sharper handling. It takes a 2.4" tyre in the back which I think is a key consideration in buying a hardtail these days. Not much penalty in riding a wider tyre in an already light bike and gives more comfort in the rear end.
fastezzie
by fastezzie
grantrstubbs wrote:
Fri Oct 22, 2021 12:04 am
Can rule out the Canyon due to the internal wedge seat clamp. I will never purchase another bike with one of those! Madness! :smartass: Rant over.
fastezzie
by fastezzie
viragevitesse wrote:
Fri Oct 22, 2021 1:54 am
I absolutely agree and can't imagine going back to a narrow tire. Even just having mud clearance is crucial. I rode an XTC for a week a few years back and remember liking the ride quality a lot but the head angle was absurd.
Hexsense
by Hexsense
Yeah, I still prefer 2.25" tire in the back of full sus mtb. But for hard-tail, it'd be widest tire that fit in there.
Low knobs, speedy and light casing 2.4 or larger is preferred on hardtail over 2.25 with medium knobs all round tires.
jrod88
by jrod88
Maybe we'll get some specs on the new drop stay Cannondale.
CAAD13 Disc
Tallboy
by Tallboy
I'm interested in this question too as I run 2.25 usually and definitely find the back wheel bumps around a bit. I find its worst on loose rocky trails (not often in xc races but sometimes on marathon courses here) and field edge paths which tend to be quite rough.
Do you find the comfort and grip outweighs the extra rolling of eg a 2.4? Do you run slightly higher pressure in a bigger tyre to compensate?
"I want to absorb all of your pop culture"
stoney
by stoney
Higher pressure in a tire is only faster on smooth tarmac or a metal drum test. On bumpy trails lower pressure is smoother and faster as the tire can conform to the trail. The men's XC World Championship was won on 2.4 size Maxxis Aspens, so yes 2.4 size tires can be fast. It just depends on the tread pattern and tire compound.
ghostinthemachine
I run lower pressures in larger tires.
I would guess most of the top racers (WC) will be running tubeless of that size at between 1.2 and 1.5 bar. I know some of the liter riders in the women's competition are running ~1 bar on some course/tire combinations.
