What trainer do you use for your Aethos?
AethosOnTurbo
by AethosOnTurbo
Hello,
I recently bought the Aethos and have been loving riding it outside.
I am looking to get a trainer for winter and I tried my friends Wahoo Kickr and I couldn't get it to fit :( .
Is anyone using the Wahoo Kickr or Tacx Neo with their Aethos? How does it fit?
(I note that on the Wahoo webpage there is no mention of Aethos incompatability, but maybe it has not been reported? https://support.wahoofitness.com/hc/en- ... patibility)
WouldLikeToBeLighter
by WouldLikeToBeLighter
I have an Aethos and a Tacx Neo 2T, the two shall never meet. The Aethos will stay in the house and the Neo will remain in the garage/pain cave with a Cervelo P2 mounted to it. The Aethos is far too nice to subject to the turbo and it won't get me up the pretend virtual hills any quicker 😂
TobinHatesYou
by TobinHatesYou
If you can afford an Aethos, you can afford a spare bike to park on the trainer permanently...or a Stages Smartbike SB20 or KICKR Bike.
I actually go hard on the trainer and sweat profusely in the process. No amount of care can win the battle against corrosion. I utilize all the tools available. I have a sweatcatcher, I have 3 high-powered fans, I wear a sweatband, I spray a waxy protectant on my frame and fasteners, I wipe the bike down, I leave the fans running. My FD cage, stem/steerer clamp bolts, STI shifters, Hollowtech steel crank spindle, etc. are still rusting.
mrlobber
by mrlobber
What exactly is the thing which "does not fit"? If you have the axles right, the only thing could be the rear caliper? In that case, you can't really do anything.
On the other hand, I'm 100% with what Tobin said. For the trainer, the most crappy bike fits as long as you have working rear shifting. You don't need the brakes, front shifting, or, with some DIY engineering, even the front wheel. I run no bar tape either (because there is going to be a towel over the front of the bike anyway).
Bikes I know something of:
Vial Evo Ultra | SS Evo 1 & 2 | R5D | S5 | S5D | P5 | O2 V.A.M D | AR FRD | Addict SL | Plasma 3 | SL6 | Orca | Orca OMX D | Boone D | 596
TobinHatesYou
by TobinHatesYou
mrlobber wrote:
Fri Oct 22, 2021 8:16 am
Lol, I'm the same. One side has no bar tape, the other has bar tape that is completely worn through. Every single braze-on on the aluminum paint is corroding and causing the paint around it to bubble.
AethosOnTurbo
by AethosOnTurbo
WouldLikeToBeLighter wrote:
Thu Oct 21, 2021 9:12 pm
Do you know if the Aethos could fit on the Tacx?
AethosOnTurbo
by AethosOnTurbo
TobinHatesYou wrote:
Fri Oct 22, 2021 6:30 am
I hear you. I looked at the Kickr bike but like the idea of being able to pack the trainer away
AethosOnTurbo
by AethosOnTurbo
It would not sit flush
AethosOnTurbo wrote:
Sun Oct 24, 2021 11:52 pm
No idea if it would fit, but I suspect the rear caliper my foul the Neo casing. My CAAD12 doesn't fit but that's in a 135mm rear axle but the Aethos is a 142mm so it may work, but I'm
Never going to try it.
pmprego
by pmprego
I know of someone using exclusively for ERG mode and using it as a single speed. Not even shifters he has.
Basscadet
by Basscadet
pmprego wrote:
Tue Oct 26, 2021 3:47 pm
Using an Aethos with a Neo 2T?
pmprego
by pmprego
Basscadet wrote:
Sat Oct 30, 2021 4:18 pm
Hell no!
TobinHatesYou
by TobinHatesYou
The Neo is one of the worst trainers for disc-brake compatibility. The KICKR is probably the best. With the KICKR, the are endcap compatibility issues with some dropouts and it is entirely a Wahoo problem, not the bike manufacturers'
Basscadet
by Basscadet
Mon Nov 01, 2021 2:03 am
I don't doubt what you have written here but so far I have had 4 disc brake bikes from Cannondale (Topstone), Trek (Checkpoint), Canyon (ultimate clx), and my Open UP all on my 2T without any issues. These are all Shimano brake bikes, so maybe that has something to do with it.
