Best "no proprietary parts" bike ?
Karvalo
by Karvalo
UpFromOne wrote:
Fri Oct 22, 2021 11:33 pm
2. The frame bits are very, very proprietary. Even by Spesh standards. (LOL, he just said "standards"!) The bottom bracket cable guides don't seem to fit any other model. While the rear derailleur mechanical cable guide fits ONE other Spesh model ('17 Epic), most if not all these bits are unique to the frame. Sure, lots of frames have proprietary frame bits. But the Aethos outdoes it.
That's not how the word works.
It doesn't matter whether the one Specialized cable guide that works on the bike can fit 50 other models or no other models, it's still the one part you can use therefore it's equally proprietary.
Robius
by Robius
fizzaz wrote:
Thu Oct 21, 2021 2:07 pm
Felt FR is completely standard parts.
Second for the Cinelli's.
Several of the big names have lower-tier bikes that fit that. Emonda ALR for example
Kinesis Aithein is a good example of alloy with totally normal parts (save for a larger seatpost diameter)
+1 for Felt FR FRD. It's an amazing frame. It'll be really hard to find a frame that has better tolerances and carbon quality. Maybe Time and Look frames might be on par.
2016 Felt AR2 Di2
Retired:
2017 Giant TCR Pro 2
2015 Cannondale Synapse 6
ichobi
by ichobi
picking out bike bits just to say it’s all proprietary is just grabbing straws now. Find me bikes that don’t use special bits for their tiny hardwares. Almost all brands and models don’t use the same deraileur hangers. Even my old 2013 Ridley Fenix use weird ass hanger that takes me forever to source replacement.
BigBoyND
by BigBoyND
Especially cable guides. Can't lose it since cables hold it in place and I've never seen one damaged either.
2019 Spec Venge 58cm <6.9kg target
- R9270, Quarq, i9.65, Look Xpro
2021 Canyon Speedmax Disc CF8 XL heavy
- R8000, P2M, SwissSide 62/80, Speedplay Aero
Retired:
2020 Pina Prince 59.5cm 7.4kg
2017 Cervélo P5 58cm heavy
Coolcat
by Coolcat
BigBoyND wrote:
Sat Oct 23, 2021 2:07 pm
Plastic cable guides (cable stops) can - and will - break before the frame itself breaks. I have had it happen a couple of times. So I keep some spares for my frames. Must be bought beforehand when still available!
There is quite a lot of stress on rear brake cable stops. I think metal housing, for example Alligator, puts even more stress on the guides since the housing doesn't compress, so much more of the load has to be carried by the cable stops. Also, the front cable stops move when turning the handlebars, which wears them out slowly. The fit gradually becomes loose. I wish manufacturers made metal cable stops instead.
This is probably less of an issue (maybe no issue at all) for bikes with electronic shifters and hydro brakes.
wheelsONfire
by wheelsONfire
spartacus wrote:
Fri Oct 22, 2021 10:23 pm
wheelsONfire wrote:
Fri Oct 22, 2021 10:17 pm
Aethos as the best!? Wow, i must be the only one to think NO!
Lightest frame you can get
Lifetime warranty
No proprietary parts
Threaded bottom bracket
Supposedly rides amazing
By all means what's better?
I guess if you insist on having rim brakes it's a deal breaker.
I would still (personally ofcourse) pick a custom made like Argonaut.
Bikes:
viewtopic.php?f=10&t=156137
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
ipenguinking
by ipenguinking
I'm ordering a custom ti frame after my DA 9200 components arrived, hopefully by next Spring. This bike will have BSA BB, CK Inset HS, 1 1/8 stem, 31.6 round handlebar, 27.2 seatpost etc.
MrCurrieinahurry
by MrCurrieinahurry
How about a standert? Not carbon but a different option perhaps?ImageImage
Supersix56
by Supersix56
I think proprietary is the best! Looks so cool!
Saves you money in the longrun as you get more race wins and if you sell your bike each year and replace you dont have to worry about getting spares which can cost like 20euros just for a plastic cable guide on the BB etc.
Just swap your bikes out every 2 years and you will save money in the longrun on parts that wear out.
Portland based
Sagan SS 2012 Team Issue
Maddie
by Maddie
Still selling fm066sl frames with your logo, Durain?
Supersix56
by Supersix56
Maddie wrote:
Sun Oct 24, 2021 7:49 pm
Are you ESL? I see he is still selling them for 3k USD in custom paint. Id buy one of my wife would allow me 2 bikes but like most people here Im not allowed. Happy wife happy life.
Portland based
Bb13
by Bb13
What about Origine bikes ?
https://www.origine-cycles.com/fr-FR/
I have one, and it' s a nice bike.
Size 58 and 7,4 kg as shown on the picture
daninplymouth
by daninplymouth
I'm running a mason definition. Not very light but rides really well and holds speed fine. That was part of my reason for buying was seatpost, handlebars, bb are all standard sizes so easy to chop and change
