Best "no proprietary parts" bike ?
Maddie
by Maddie
Depending on the budget, I would also say Specialized or S-Works Aethos. Lightest disc frame currently available, future proof, very easy to service. And even though it's a Spec frame, you don't see them at every corner. Can also take mechanical (except S-Works) if that's important. Depending on the region, availaibility is very good to so-so. Only negative in my view: expensive
fastezzie
by fastezzie
Supersix Evo with a BB infinite unit installed. I consider it the precursor to the Aethos, both bikes designed by Peter Denk. And rides fabulous.
ArtV
by ArtV
Ridley Helium SLX?
Sent from my SM-T860 using Tapatalk
BigBoyND
by BigBoyND
If Aethos doesn't qualify for this thread, I don't know what does. Standard stem, Bb, and seatpost. Compression plug can be changed to anything you want. Electronic compatibility and price don't make it non-proprietary so that's a weird argument. Most RD hangers are bike specific. Do hanger standards even exist? So what's left? Headset bearings?
2019 Spec Venge 58cm 6.9kg
- R9270/R8170, Quarq, i9.65
2021 Canyon Speedmax Disc CF8 XL heavy
- R8000, P2M, SwissSide 80 + Citec Disc
Retired:
2020 Pina Prince 59.5cm 7.4kg
2017 Cervélo P5 58cm heavy
pmprego
by pmprego
The definition for non-proprietary part must be related to the option of replacing parts coming from other manufacturers other than what originally came stock on the bike.
In that sense, the bb being pressift or threaded does not qualify as proprietary/non-proprietary. It's just a characteristic. On a pressift system one can use whatever brand bb as long it's pressift compatible. The same goes for the threaded option. One can use whatever brand bb as long as it's threaded compatible.
Lina
by Lina
BigBoyND wrote:
Fri Oct 22, 2021 3:54 am
The Aethos does have a proprietary front caliper mount. But IMO that's almost in the same territory as RD hangers. And unlike hangers you shouldn't need to ever replace it.
Stendhal
by Stendhal
Orbea Orca OMX (7.31 kg), Chapter2 Rere Tauhou (7.53)
Retired: S-Works SL6, LOW mki, Dogma F10\F8, Lapierre Pulsium, TIME Fluidity, Wilier Cento1, Ridley Noah, Cyfac Cadence, Cervelo S2\R3\Aspero\R5, Felt Z25, Klein Quantum, Cannondale 2.0
GS100
by GS100
Karvalo wrote:
Thu Oct 21, 2021 3:14 pm
GS100 wrote:
Thu Oct 21, 2021 1:34 pm
Correction BSA.. ok so fine it's got a round seatpost and non integrated stem but this is a seriously high end bike - nearly £12,000 here in the UK for last year's model. Special parts that should you need to replace any like for like, it's gonna cost/ possibly be scarce.
You don't need to replace like for like, that's what non-proprietary means. You can do whatever you want.
Ah ok cool so just get your £12k Aethos kitted out with Alibaba special parts? lol ;)
But seriously, someone spending to get an Aethos are very unlikely to give a s**t about the hassle, if any, of priorietary parts! it's just a daft suggestion IMO.
Mocs123
by Mocs123
You're probably not going to want to replace anything on an Aethos right now, as they are spec'ed pretty well, but you could get a frameset and build it up yourself, or you could replace/break parts later on and replace them.
One thing I would worry about on a bike with proprietary parts, like for example the Canyon Aeroad, is what if break a seatpost five or six years from now? Will Canyon offer replacements? It's not like you can use any seatpost.
2015 Wilier Zero.7 Rim Brake - 6.37kg
2017 Trek Domane SLR-7 Disc Brake - 8.36kg
Karvalo
by Karvalo
GS100 wrote:
Fri Oct 22, 2021 4:25 pm
You are unaware of the existence of any other standard finishing kit apart from Roval Alpinist or Alibaba knockoff?
I'd suggest doing a bit of research before you start speccing your next bike :smartass:
BigBoyND
by BigBoyND
Yeah I was thinking the S-Works customer would be looking at Tune, Extralite, THM, Darimo, etc. Not Alibaba....
Retired:
wheelsONfire
by wheelsONfire
Aethos as the best!? Wow, i must be the only one to think NO!
Bikes:
viewtopic.php?f=10&t=156137
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
spartacus
by spartacus
wheelsONfire wrote:
Fri Oct 22, 2021 10:17 pm
Lightest frame you can get
Lifetime warranty
No proprietary parts
Threaded bottom bracket
Supposedly rides amazing
By all means what's better?
I guess if you insist on having rim brakes it's a deal breaker.
openwheelracing
by openwheelracing
The best part about the Aethos is the ride quality and weight compared to all other heavy and harsh riding disc brake bikes. Most disc brake bikes need big tires and lower pressure hence the current trend. Aethos is incredibly light and you can toss around with immediate acceleration. Weight is everything for climbers and everyday riders. Aethos is basically a top notch rim brake bike but with disc brake and huge price premium.
Imagine an even lighter Aethos: Aethos with rim brake
UpFromOne
by UpFromOne
Lina wrote:
Fri Oct 22, 2021 7:46 am
1. The front flat mount adapter has the fork holes closer than the usual flat mount. But some other flat adapters (like Juin) also happen to have that closer hole already drilled into it. So in a pinch one of those would work instead of the Specialized specialized part.
2. The frame bits are very, very proprietary. Even by Spesh standards. (LOL, he just said "standards"!) The bottom bracket cable guides don't seem to fit any other model. While the rear derailleur mechanical cable guide fits ONE other Spesh model ('17 Epic), most if not all these bits are unique to the frame. Sure, lots of frames have proprietary frame bits. But the Aethos outdoes it.
3. For anyone still confused, the non S-Works models, i.e. Pro/Expert/Comp, are all the same frame and can accept mechanicals.
Signed,
Luddite and Proud
