Campagnolo Ekar - full outer housing?
Hi guys,
I have just received the Ekar groupset and I can see that the shifter housing included is very short. As this is a gravel bike, it needs to run full outer housing.
Is it possible to buy the maximum smoothness outer housing alone? If not, which other housing would work fine with the new Campy cables?
Thanks!
Thanks!
Fuji Cross 1.5 - Shimano 105 5800 | Cinelli Superstar Disc - Record 12s | Custom steel Karamba - Ekar 13s
This is what you need, but it’s currently out of stock:
https://www.condorcycles.com/products/c ... 7701873814
I think Campagnolo should include a full length housing with the shifters…
Are you sure about this? I built up a Ridley Kanzo gravel frame in March this year with Chorus. That groupset also comes with short gear outer casings. To begin with I was thinking I would need full length gear outer but I examined the kit of small parts that came with the frame carefully and realised the cable entry block on the headtube could terminate the gear outer. You can see it in the photo below. The rear brake hose continues through but the Maximum Smoothness gear outers terminate there. The inner wires are routed inside the down tube via a cable guide to the front and rear mechs. Perhaps your frame can do the same?
cycling / nature / music
Actually, it is the other way round - I am still to design a frame which will be custom built, but my experience with gravel riding so far is that without full housing the shifting quality degrades too quickly. Thus I wanted full insulation from bars to the derailleur.Miller wrote: ↑Thu Oct 07, 2021 2:23 pmAre you sure about this? I built up a Ridley Kanzo gravel frame in March this year with Chorus. That groupset also comes with short gear outer casings. To begin with I was thinking I would need full length gear outer but I examined the kit of small parts that came with the frame carefully and realised the cable entry block on the headtube could terminate the gear outer. You can see it in the photo below. The rear brake hose continues through but the Maximum Smoothness gear outers terminate there. The inner wires are routed inside the down tube via a cable guide to the front and rear mechs. Perhaps your frame can do the same?
Hi, this might help: https://ispithotfire.com/2024/03/16/the ... -mechanic/
