Upgrade to 12s Campagnolo EPS
slick1
by slick1
Hi all.
I have a LOOK 695 and it has Campagnolo SR 11s mechanical groupset and Fulcrum R1 wheels.
I'm thinking about upgrading to 12s Campagnolo EPS and was wondering if I need to change the front chainrings seeing as though the chain is thinner.
I know the 12s cassette will fit on the existing 11s rear freehub but just not sure about the front chainring. Do I need thinner front sprockets?
What I like not is that the conversion won't be as expensive as a complete upgrade. I am keeping the brakes and the cranks are the LOOK ZED2. I only need the battery, wiring, shifters, front and rear derailleur.
Cheers
Sent from my SM-N976B using Tapatalk
joeyb1000
by joeyb1000
You can use an 11s crankset on 12sEPS, but not 12s mechanical.
micky
by micky
Isn't the chainline a problem with 11s cranksets?
slick1
by slick1
joeyb1000 wrote:
Sun Sep 26, 2021 1:59 pm
Thanks for your reply. I wonder why eps but not mechanical?
i have praxis works front chainrings so i guess worst case scenario i'll need to replace them.
joeyb1000
by joeyb1000
slick1 wrote:
Mon Sep 27, 2021 12:35 am
EPS v2 - v4 can adjust for the position of both the inner and outer chainring. So, once you set it up, you trim the outer chainring a couple of clicks to match the crankset you have.
12s mechanical FD have a different design than 11s. It just won't work as well if the chainrings are not 8.0mm apart.
I measured the teeth on the 11s and 12s chainrings and saw no difference.
Just an FYI, the first six cogs on Chorus and SR cassettes are the same.
coasta007
by coasta007
joeyb1000 wrote:
Mon Sep 27, 2021 2:29 am
thanks. Definitely better off going with the chorus 12s cassette. Cheaper and probably last longer. Weight saving is minimal and insignificant when body fat has to be lost.
On another note, if i upgrade from 11s campy to 12s Campy EPS, I only need front and rear derailleurs, shiufters, EPS V4 Power Unit (battery), EPS V4 interface, 12s cassette, 12s chain. I'm using my current brakes and ZED2 crankset so the build cost wont be as bad as having to buy the brakes and cranks as well. What do you recommend for the interface? Internal or external?
Using Tapatalk
coasta007
by coasta007
Using Tapatalk
usr
by usr
coasta007 wrote:
Mon Sep 27, 2021 10:55 pm
Why would they? The weight saving is from more volume milled away (in places where it's definitely not needed), not from a lower density material. If there is a difference in material (I don't think there is), it would be softer for the cheaper version: milling cost is (in first approximation) volume removed x hardness.
jzinckgra
by jzinckgra
Anyone know when EPS will be available again? Trying to order SR EPS hydro and most places are out of stock
GS100
by GS100
usr wrote:
Mon Sep 27, 2021 11:36 pm
Assume because the last 6 are titanium on SR..
On that note, I've found the shift from the last steel cog up to the first titanium to be poor on my SR 11 cassette on EPS. Seems much better on chorus and I seem to have to reset the EPS each time I swap for proper shifting across the range. Not sure if I've got a dud but I really can't recommend from my experience.
usr
by usr
GS100 wrote:
Wed Sep 29, 2021 8:14 am
They are steel, no titanium cogs for 12s Campag
GS100
by GS100
usr wrote:
Wed Sep 29, 2021 8:31 am
I did not know this!
Probably not a bad idea, given my experience with SR 11 cassettes..
Not sure why you'd stump up the extra for SR though now.
usr
by usr
Ca 90€ for ca -40g, that's not worse than other premiums you pay for Record or Super Record over Chorus. If you believe that they differ in more than weight, feel free to keep believing. (well, rim brakes are still the last 11s design for Chorus and some bearings are different)
