Factor LS 2021 AXS
cerro
by cerro
LegPower wrote:
Fri Oct 22, 2021 12:52 pm
req110 wrote:
Thu Oct 07, 2021 8:10 am
There is no eagle RD on this bike. I have Force AXS with Garbaruk cage + XPLR cassette.
I don't see why XX1 Eagle AXS shouldn't work on this bike.
Have you tried this setup with a 10-33 or 10-36 cassette? I just ordered my Garbaruk cage and want to have two sets of wheels. Trying to figure out my second cassette.
10-36 works fine with Force short cage+garbaruk cage. Had 10-44 on one set of wheels and 10-36 on the other before :)
LegPower
by LegPower
cerro wrote:
Fri Oct 22, 2021 7:28 pm
Awesome, thank you! Did you ever try running an Eagle XX1 chain or always the flat top?
req110
by req110
Always x01 chain
cerro
by cerro
LegPower wrote:
Fri Oct 22, 2021 8:50 pm
Always flattop as the cassette and chainring is made for it. And they last really long :D
req110
by req110
I have rebuilt the factor LS from scratch.
The Force AXS gruppo will go to gravel bike of my GF which i am going to build.
I sold my Supersix and moved Red AXS 2x12 to this factor.
Now considering best tire options. I will go for some slick 35-38 tires, so i can ride some soft gravel but fast enough on tarmac.
- challenge strada
- panaracer gravel king slick
Or something else.
Main motivation to do this switch is
1) price of supersix frameset dropped below factor LS frameset
2) the geometry of factor LS, even being marked as gravel, is more road than supersix
3) i believe the stiffness of factor LS is the same as supersix
4) similar for aero
5) i am living in area which i can consider as "best for gravel"
6) drivers >>> everytime i ride a road bike, i usually get angry because of some car passing me too close. now we have a new law, when drivers must pass you at least from 1.5m... but some drivers does not respect that.
7) i needed gruppo for gravel bike of my GF which i am going to build.
Now considering
1) switch zipp 303s to zipp 303 FC
2) switch 2x12 (48/35 10/33) to 1x12 (44T 10-44)
All from my side.
Gary71
by Gary71
Beautiful looking bike req110. How does she ride compared to the Supersix? Full report please........, I have the current Supersix (sadly a warranty replacement for my SS evo2) and it just doesn't inspire me. I am curious to hear your thoughts on how the factor rides; as a road and, as a gravel steed?
kode54
by kode54
@req110
Regardless of the 3 feet rule, cars buzz me all the time on purpose. Happened to me this morning as I was riding. Plenty of room for car even if they were close to double yellow so no excuse there. Seems as though it has gotten worse during pandemic as drivers are taking out their pent up anger on the road.
- Factor 02 VAM Disc
- Factor LS Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
- Moots Vamoots Disc RSL Ti
- AX Lightness VIAL evo Rim
req110
by req110
Hey gents. Thank you.
Supersix 54cm vs factor 54cm
- factor is around 300g heavier (i can probably live with that)
- aero of frameset i think similar
- i am using same cockpit, farsports f1
- riding 40% nice tarmac, 30% crap tarmac, 30% unpaved
- design factor looks better in my opinion since
- i can only have this bigger headset cap with handlebars on top of them, while on supersix i've had to have spacers).
- supersix head tube angle was 2 deg more slack, making my -10deg cockpit looking like -7deg very upright
- stifness of frameset, i can't test now because i have 40c tires, but factor claims that LS is similarly stiff as O2 climbing machine.
- i just have to figure out some ideal tires. these tufo gravel thundero are not fast at all. i will probably order terra speed 40c once again, they were really fast! other option is challenge strada bianca htlr, but those are very expensive, and also slick with risk of challenging installation.
- bike fit!
supersix has stack 556
factor has stack 565
Given the fact that slick headset cap is around 2cm, i have the saddle>handlebar drop around 6.5cm, which is supercomfortable and respecting bik fitter suggestion, compared to supersix, where i had around 8.5-9cm...
But i purchased supersix first and went for bike fit later, where we realized that stack of the supersix needs me to run couple spacers, which made the bike totally ugly.
Gary71
by Gary71
Thanks, I appreciate your reply and comments.
I'm guessing most of the 300g would be in the bigger tyres (?); or are you saying that it is 300g for the frame system? Frame, fork and the hangers etc?
I am a little worried about the stack - as you point out - it is 10mm taller and I have my current Supersix almost slammed with a -17 degree 110 stem. I worry that it will be too tall.
I could size down, but then there have been comments about toe overlap and sizing down will only make this worse.
How do you find the turn in an front end of the LS? My fear in getting another gravel bike is that it turns in like a boat and just wants to sail to the other side in under steer :(
req110
by req110
300g I mean frame, fork, etc.
If I consider bigger tires and wheels, It would be 1kg difference.
I have slight toe overlap here as well.
I have taller spacer under handlebars. You can use the short one to reduce stack by 1.5cm.
Turning I think fine.
