Tantan/Winow GR039 Gravelbuild (7.2kg)
kroem
by kroem
This is my gravel/winter road bike build.
Yes, frame is a chinese open mold. I've had good experiences ordering through direct contacts, but you best be prepaired to send emails back/forth. Original bar/stem had too long reach and really crap cable management, so bought a Yoeloe H10. Had some issues getting the headset fit well with the Yoeleo bar, but bought a Deda headset and used the compression ring from that, perfect fit now. Integrated cables looks great, but was ... frustrating :D
It rides very nice, racy geo but that's what I want. Gonna swap calipers for RX4's in the future.
Part Name Weight Note
Total (gram) 7285,5
Total (lbs) 16,06
Frame Tantan GR039 1070
Fork Tantan GR039 393
Seatpost Hylix 27.2 165 * estimate
Seat collar Tantan GR039 included 18
Saddle Berk Lupina padded 132mm 94 * estimate
Handlebars Yoeleo H10 306
Tape + plugs Bike Ribbon cork Black 39
Stem - 24
Headset Yoeleo/Tantan/Deda mix 70 Bearings ca 34g x2
Top Cap Carbon-Ti 58 Expander + top cap
Spacers Tantan GR039 included 34
Levers/Shifters
Front Brifter Lever Shimano GRX ST-RX815-L 379
Rear Brifter Lever Shimano GRX ST-RX815-R 386
Brakes
- Front Caliper Shimano GRX BR-RX810-L
- Front Pads
- Front Rotor Shimano RT-MT900 160mm 114 *
- Rear Caliper Shimano GRX BR-RX810-R
- Rear Pads
- Rear Rotor Shimano RT-MT900 160mm 114
Front Derailleur -
Rear Derailleur Shimano GRX RD-RX815 287 *
Cables/Housing
Crankset Quarq D1 dub 343
- Chainring 1 Wolftooth Direct Mount Drop-Stop B 1-way 113,5 106 + 7.5 (bolts)
- Chainring 2 -
Bottom Bracket SRAM BSA DUB 76 *
Cassette/Freewheel SROAD 11sp 10-36 280
Chain Guide/Catcher
Chain Shimano CN-HG701 250
Front Wheel Farsports Gravel 30x30 587
- Front Rim Farsports Gravel FS30/30GH-700C 345g
- Front Hub DT-Swiss 240 EXP straight pull 24H
- Front Spokes Sapim CX-ray
- Front Nipples Sapim secure lock SILS
- Front Tape/Plugs No hole rim
- Front Tire Panaracer Gravelking SS 38mm 420 * estimate
- Front Tube Tubeless + Orange Seal valve 5,5
- Front Sealant/Glue Orange Seal
- Front Skewer/Bolt J&L Thru axle 19 * estimate
Rear Wheel Farsports Gravel 30x30 692
- Rear Rim Farsports Gravel FS30/30GH-700C 345g
- Rear Hub DT-Swiss 240 EXP straight pull 24H
- Rear Spokes Sapim CX-ray
- Rear Nipples Sapim secure lock SILS
- Rear Tape/Plugs No hole rim
- Rear Tire Panaracer Gravelking SS 38mm 420
- Rear Tube Tubeless + Orange Seal valve 5,5
- Rear Sealant/Glue Orange Seal
- Rear Skewer/Bolt J&L Thru axle 26 * estimate
Pedals Assioma Favero with M-FORCE 8 body 329 7799 + 1000 Xpedo body
Bottle Cage 1 Tune Wasserträger MTB 20
Bottle Cage 2 Tune Wasserträger MTB 20
Miscellaneous 1 Shimano Di2 BT-DN110 Batteri 55 * estimate
Miscellaneous 2 Shimano Di2 bar-end junction 20 * estimate
Miscellaneous 3 Shimano Di2 SM-EWWU111 Wireless Unit 3
Miscellaneous 4 Shimano Di2 cables + 4-port + y-cable 50 * estimate = 20g + 5g + 25g
Miscellaneous 5 Capgo Noise Protect
Canyon Ultimate SLX 6.7kg (crashed/dead)
Tantan/Winow GR039 7.2kg
All-City Space Horse (scrapped, for now)
Waltly Gravel (stolen... :evil: )
PX Spitfire Ti
xkcd
by xkcd
looks very good!
can you mount fenders and a rear rack, referring to the bolts at the rear drop out and seat stay?
kroem
by kroem
xkcd wrote:
Mon Aug 09, 2021 9:51 am
looks very good!
Yes, I believe you can (but I haven't tried :) )
Thanks!
PX Spitfire Ti
nismosr
by nismosr
do you have more pictures and what size is it ?
2020 Colnago C64 Mapei - SR12 EPS - LW Meleinstein
2022 Cipollini Bond 2 - SR11 Disc EPS - Bora WTO 45 - P2max
2021 Basso Diamante SV - SR12 Disc EPS - Bora WTO 60
2022 Basso Palta 2 - Rival/GX AXS - Zipp 303s
kroem
by kroem
nismosr wrote:
Mon Aug 09, 2021 1:29 pm
I can take a few more.
It's a size 54
PX Spitfire Ti
kidrob
by kidrob
Very exciting build, well done!
nismosr
by nismosr
Whats the widest tire it can accomodate?
matcav
by matcav
nismosr wrote:
Tue Aug 10, 2021 12:56 am
700X42C, according to TanTan.
I've just ordered it too, let's see how it goes.
kroem
by kroem
Sorry... haven't checked the forum in a while.
I run 700x43 and plan to test 650Bx45
PX Spitfire Ti
floriansantana
by floriansantana
Wow, I’m excited. I think about building one for myself. Can you post more pics to even get me more stoked? 😍
How much did you pay for the frameset with bars and seatpost? And how long did the shipping take? Does Tantan offer tax pre paid shipping?
Cannondale SuperSix Evo Disc
Cannondale SystemSix HiMod Disc
@floriansantana
kroem
by kroem
floriansantana wrote:
Sat Dec 25, 2021 3:59 pm
I dont really have any fun pictures now, because it's stuck here inside...
PX Spitfire Ti
matcav
by matcav
kroem wrote:
Mon Aug 09, 2021 8:32 am
[...] bought a Yoeloe H10. Had some issues getting the headset fit well with the Yoeleo bar, but bought a Deda headset and used the compression ring from that, perfect fit now.
Hello, thanks for sharing this superb build.
I'm considering going for the same handlebar setup (yoeleo H10) and I'm wondering if I need to add the Deda compression ring as you mentioned. In case, would it be the first or the second kind?
(ACR vs DCR)
https://www.bikeinn.com/bike/deda-compr ... 38244301/p
https://www.bikeinn.com/bike/deda-compr ... 38244300/p
kroem
by kroem
matcav wrote:
Tue Jan 18, 2022 10:57 am
(ACR vs DCR)
I bought a whole headset for DCR system, I believe... So should be the first one.
PX Spitfire Ti
matcav
by matcav
kroem wrote:
Wed Jan 19, 2022 12:00 pm
(ACR vs DCR)
Thanks for replying.
Is there any other component you used from the Deda headset, apart from the compression C ring (and the expander maybe)?
kroem
by kroem
matcav wrote:
Thu Jan 20, 2022 4:59 pm
(ACR vs DCR)
No, not with this handlebar, just needed the c ring.
Actually... Now that you mentioned it - I do also run a small small Shim (cut in a c shape) extra on top on the c ring because I was not happy with the gap. I hope that makes sense...
PX Spitfire Ti
