Lightweight seatpost for gravel?
nickf
by nickf
Anyone using a Darimo post on their gravel build? I want something light but also set and forget. I like my Darimo post on the road bike but I have to keep my eye on it from coming loose. I use blue loctite but still have to re torque it from time to time.
Steve Curtis
Location: Hampshire UK, Dublin Ireland and Geneva Switzerland.
by Steve Curtis
Well if you have to do that it's a pretty shit seatpost. However, they do look nice.
Even an Elita one at 110g in 31.6 doesn't slip or need to be messed with and that's a £20 seatpost on a hack bike.
spdntrxi
by spdntrxi
I've been using a Darimo (31.6) for awhile now.. no issues, no slipping
ooo
by ooo
does it slip down or saddle become loose?
you can fix slipping post by second clamp BBB PostFix BSP-97 (like wva did) and/or carbon paste
saddle mount can be fixed with loctite and new bolts, but this is not guaranteed
nickf
by nickf
The bolts holding the saddle adjustment barrels work loose. Not often but it does happen. Not sure what's up. All I know is that it needs to be bulletproof. Might take it apart and try more loctite.
eurperg
by eurperg
Schmolke TLO. Very comfortable over rough terrain, no creaking and zero adjustment needed after riding 2000 km’s on gravel. And there’s just grease in the bolts, no Loctite.
jmh
by jmh
Ritchey Superlogic checked all the boxes for me. 138 grams is light enough for my gravel needs.
SilverSteve
by SilverSteve
+1 for elita one seatpost.
I have it on my gravel bike with zero slippage.
Weight 106grams after trimming about 4" off 350mm post...
cerro
by cerro
+1 for Darimo, using one on my Factor Ls. Working flawless and superlight
eurostar
by eurostar
Hope do one with 15mm layback. 185 grams. I've not used it. They say it's strong enough for downhill. https://www.hopetech.com/products/acces ... seat-post/
ukracer
by ukracer
Steve Curtis wrote:
Sat Jul 31, 2021 5:17 pm
Do you have link for this seatpost please?
jacobeh
by jacobeh
jmh wrote:
Sat Jul 31, 2021 9:51 pm
Same here, though mine says 148g :shock:
SilverSteve
by SilverSteve
ukracer wrote:
Thu Aug 26, 2021 6:12 am
Here's a link to the Elita One Aliexpress Store
https://elitaone.aliexpress.com/store/2 ... 43058wDDJ4
