Knee pain on indoor trainer only
ksavostin
by ksavostin
Hello. So here is my problem. I can ride with no issue outdoor for hours, but as soon as I ride the same bike on my trainer a few days later my knee starts to hurt. I can't describe the pain location, somewhere inside. I tried elite direto and tacx neo2. I did bikefit, the fitter didn't find any weird movements of my knee or anything which can be related to the pain.
Has anyone with similar issue tried rocker plate? I would buy something like Saris mp1 or similar if it can solve the issue.
Worst case scenario - I will buy fat tire bike and will do my training on the snow in the winter (I am from Alaska).
nowtaps
by nowtaps
Why not try a roller trainer? It's a cheaper solution and they're pretty easy to learn
eeney
by eeney
I think indoor trainers bring out issues that you don't experience outside because of the stationary and repetitive position. I ride mainly indoors now and struggle with knees, feet, etc. Which I didn't when I rode mostly outdoors.
A lot of people like rocker plates, gives much more movement and variation which can be more comfortable. May be worth a try if you can borrow/rent one. I made one cheap and used it for some time. As I say, some people love them for indoor riding. I've been told rockers with fore/aft movement are better for sprint power, but never tried on (expensive for my cheapo budget)
mcfarton
by mcfarton
Have you considered cross training? Running, rowing, yoga, weightlifting, or anything else? You don’t have to cycle year round.
Maybe you should get a different bike fitter. Have you ever had your cleats fit? I don’t understand when people say inside is different than outside. It’s the same bike it should be the same power and fit. Maybe the fresh air keeps you from noticing the little things.
bikewithnoname
by bikewithnoname
The difference inside is that you are in one postion almost all the time, you only stand on the big efforts, and you don't let the pressure off the pedals for the full session (unless you're supertucking down Alpe du Zwift).
If you have pedals that let you adjust float I'd try that as a first step. Secondly I'd suggest a small drop in the saddle height, around 5-7mm and see if that makes a difference a little less knee angle might help.
Oh and stretch, stretch and strech some more. Ankle, calf, thighs, hip flexor
TobinHatesYou
by TobinHatesYou
bikewithnoname wrote:
Fri Jul 30, 2021 12:57 pm
Heh... I stand more indoors than I do outdoors because my sitbones need relief more often indoors.
bikewithnoname
by bikewithnoname
Yeah, your sit bones hurt because you've got constant pressure on the pedals so naturally the pressure builds up faster.
The question is; if you have to stand does that mean your fit needs tweaking or a new saddle so you can stay seated for longer?
The answer will depend on whether you spend more time on the trainer than the road I guess
TriJoeri
by TriJoeri
ksavostin wrote:
Fri Jul 30, 2021 6:06 am
I've had this as of 2 months ago.. Previously I could happily ride for up to 5.5h indoors with only slight discomfort in the nether regions after a few hours.
Lately I've been getting a pain on the inside of my left knee which seems to be similar to the one when your cleats are setup wrong, but mine haven't changed and neither has the bike fit on my road or TT bike in the last 2 years. Switching between my road shoes with grey Keo cleates and tri shoes with red Keo cleats also doesn't make much of a difference.. After about an hour I start to feel discomfort which continues to get worse and worse if I continue to ride.
As soon as I take the bike outside, that's gone..
sychen
by sychen
I know when my quads get tight it pulls my knee out of alignment causing some pain.
Indoor training tends to cause this to build up faster due to static positions.
I use a roller or hockey ball to dig in and release the muscles.
If you have a percussive massager.. Even better.
Sent from my Pixel 4 XL using Tapatalk
iheartbianchi
by iheartbianchi
When you're outside you're rocking the bike below you. When you're indoor the bike is stationary, so a precise fit is even more critical.
Bianchi Oltre XR4
Celeste Matte
Campy SR 11spd mechanical
Bora Ultra 50 tubs
Viseon 5D / stock bits and parts
Bianchi Specialissima Pantani Edition
Campy R 12spd mechanical
Fulcrum Racing Speed 35 tubs
FSA / Deda bits and parts
ksavostin
by ksavostin
iheartbianchi wrote:
Tue Aug 03, 2021 6:44 am
Will rocker platform such as Saris MP1 partially solve this problem? I am not expecting that it will give me the same feel as on a road, but it gives some extra movement, thus I will be less stationary.
iheartbianchi
by iheartbianchi
ksavostin wrote:
Fri Aug 06, 2021 5:58 am
Yes it will help. Think of it similar to adding more "float" to your pedals - the more your bike can move underneath you, it will let your legs/joints move around a bit more to adjust to a rocking bike which can mitigate any imbalances.
Bianchi Oltre XR4
Celeste Matte
Bora Ultra 50 tubs
ksavostin
by ksavostin
Got a decent deal from local bicycle shop, bought saris mp1 display unit fior $500. Going to test my knee for a week, also I think to change Elite Direto to Tacx Neo 2T since neo has more flex than direto, perhaps it will help.
jekyll man
by jekyll man
It's probably that you're having to push more through the pedal stroke due to the turbos inertia being quite a bit different than on the road.
Official cafe stop tester
txomin
by txomin
Try MTB pedals and shoes first, free rotation is great indoors, I have a rocker plate and helps of course, but it's very expensive, I use tacx neo
