Nextie 40mm wide gravelrim! NXT45AGX
Relientk1202
by Relientk1202
Achase6002 wrote:I mounted up some 35mm Barlow pass el and they blew off the bead around 60-70psi
I was just pumping them up to make sure the bead was fully seated. I don't plan to run them at 60 or 70psi. so do u think they are good to reseat and run at 30-40psi?
I’d agree with several people above, don’t use those tires honestly I’ve had less and less luck with RH tires lately. They seem to fit perfectly then 1 psi over and they blow off. I’ve converted all my bikes over to Challenge tires (Strada Bianca for slicks and Getaways for treaded tires) and been incredibly happy with them. I ran a set of Getaways 45mm from the start fall of last year until end of summer this year. Probably over 4000 miles and the only reason they came off is because I ran over a 4” framing nail that went through both sidewalls.
Bikera
by Bikera
Relientk1202 wrote:
Sat Oct 12, 2024 4:47 am
...I’ve converted all my bikes over to Challenge tires (Strada Bianca for slicks and Getaways for treaded tires) and been incredibly happy with them. I ran a set of Getaways 45mm from the start fall of last year until end of summer this year. Probably over 4000 miles and the only reason they came off is because I ran over a 4” framing nail that went through both sidewalls....
A bit off topic (and the exact opposite of your RH thoughts) but what was your experience like in the mounting, seating and, eventually, the unseating/dismounting of those Challenge tires (and what rims r u using 'em on)? The Getaway HMTL 40c that I installed on an AG25 wheel was perhaps the tightest & most unforgiving tubeless tire mounting/seating effort I've had in 20yrs. of using tubeless. Fortunately my LBS took the tire back acknowledging the "challenge" in dealing them (and to do that I almost had tear it apart to get it unseated and off the rim). Too bad since it otherwise looked like a wonderful gravel tire!
Relientk1202
by Relientk1202
100% agree that the Challenge tires are some of the hardest tires to get on a rim. I really struggled with them on my LightBicycle AR46 (I think) wheels but once they were on they work really well. I didn’t have any issues getting them off or on once they were ridden a few times. I actually think the Challenge tires are easier to get mounted the second time than any other tires I’ve used. That first time even getting them on a rim was probably the hardest one ever done.
My issues with RH tires starts and ends with their sensitivity to pressure and rim size. I’ve had several rims from big brands (zipp, Easton, Bontrager, etc) that I could never get their tires to seat on. Once on I’ve never had confidence that they are seated well. I usually run things in the grey areas and I’m fairly okay with that. The RH tires just seemed sketchier than most.
emotive
by emotive
I ran a 35mm Bon Jon pass on the front and a 38mm Barlow pass on the rear rim tubeless for several months. Set some road descending PRs that summer!
I then switched to knobbies for winter. When I tried to mount them in the next summer I couldn’t get the beads to seal and had to run them with tubes. Seems they stretched. I’ve since switched to the Hutchinson Caracal Race 40 as my fat slick of choice. WAM29 is 44mm. They have great ride feel and roll fast. Too early to know on durability.
wirelessness
by wirelessness
Does anyone run Vittoria Air-Liner inserts? I'm wanting to run 48-50mm tires and wondering about inserts.
plrww
by plrww
svennn wrote:
Fri Oct 11, 2024 4:51 pm
I have a set of the NXT45AGX hooked.
One thing was that those tires are harder to get on the rim than anything I have tried in 27 years of cycling.
I have the same combination (NXT45AGX + GP 5000 AS TR). With tubes the tyre width is 37 mm. It was definitely a pain to get the tyres on the rim. I guess gone are the days when rims had a decent middle groove and the tyres didn't have to sit airtight on the rims. It used to be so easy and quick to switch a tube even without any tools.
The only tyre more dificult to get on the rim has been the Schwalbe Marathon Winter studded tyre.
This wheelset + tyre combination is a totally marvelous setup to ride either on gravel or asphalt.
andrewbn42
by andrewbn42
For those of you running road tires, or tires that are specked narrower than the rim, have you found durability of the tire, particularly the sidewall to be an issue? I'm curious about this setup, but not sure if I want to mess with a good thing with my experience of 25mm iw
hansotto089
by hansotto089
andrewbn42 wrote:
Tue Nov 26, 2024 3:37 pm
Exactly my question. With all the sidewall cuts on the Zipp XPLR wheels.
emotive
by emotive
I am running Specialized Mondo 35, a very similar tyre to the GP5000AS TR. they also measure 37mm but are easy to mount on the AGX45.
I haven’t suffered any punctures yet but when these wear out I will replace them with the AS TR for extra sidewall protection for peace of mind. I think if you want to run tyres narrower than the rim then sidewall puncture resistance rating should be a high consideration.
andrewbn42
by andrewbn42
Does the tread generally flatten out so it measures wider? I definitely worry about the sidewall exposure
emotive
by emotive
andrewbn42 wrote:Does the tread generally flatten out so it measures wider? I definitely worry about the sidewall exposure
Yes, each extra 1mm of internal rim width stretches the casing wider, and adds 0.3mm to 0.4mm to the external tyre width. The radius of the tyre becomes larger/flatter.
The upside is more air volume for the same tyre weight. The perceived upside is compliance to the rule of 105% though some are now refuting its importance or existence.
The downside is sidewall exposure. If you suffer from sidewall punctures in your area, discard the rule of 105 and increase the tyre width to protect the sidewall more.
sunfire2k5
by sunfire2k5
Nextie just updated the AGX line.. with SGX + Supreme SGV.
SGX = 32mm internal.
Supreme SGV - 32mm internal with very lightweight carbon. 400g weight!!
https://www.nextie.com/carbon-gravel-bi ... X-NXT45SGX
https://www.nextie.com/carbon-gravel-bi ... V-NXT45SGV
FOIL 30 MY23, Ult+105 Di2, EXS Aerover 120/360, Newmen Allround Vonoa
Ridley ASTR RS - GRX Di2 2x12 - Nextie AGX45 - Terra Speed 45mm
Ridley X-Night RS GRX+105 Di2 1x12s
Requiem84
by Requiem84
Nice! Only the wheelssets themselves available yet, not the completely build wheels. Will come though probably.
But not sure if going even wider than their 29mm is good. The weight drop of the rims is interesting.
sunfire2k5
by sunfire2k5
Requiem84 wrote:
Tue Dec 10, 2024 11:26 am
32mm is OK (ref Zipp 303 SW) when running 40-55mm tires.
I will try to order and relace my AGXs with new SGV!
Requiem84
by Requiem84
sunfire2k5 wrote:
Tue Dec 10, 2024 11:55 am
I'm going to be a bit conservative and wait for more people to try these ultra wide rims. Still a bit too many user reports of side wall flats on these type of rims due to the more exposed sidewalls. (Zipp 303 SW).
But happy to see others try it first, please let us know your thoughts once you've used them :D
