Colnago V3Rs 50s RCRD Frozen
dcj10
by dcj10
I did have a strong emotional reaction looking at that amazing frame finish :thumbup: Bike will turn heads of even the non-cyclists.
Main ride Aethos Expert 2021 https://weightweenies.starbike.com/for ... 0&t=169445
First reserve Pegoretti steel 2012 Ciavete paint viewtopic.php?f=10&t=168091
YinYang
by YinYang
Is the build done? Looking forward to the ride report between the C64 and V3RS.
Waiting for my V3RS. Shop said they have C64 in stock. Difficult decision.
fogman
by fogman
I finally had the opportunity to ride my V3Rs 15 months after ordering the frame. Here are the specs followed by some photographs.
Frame: Colnago V3Rs Size 50s RCRD Frozen Red.
Groupset: Campagnolo Super Record EPS 12 Disc.
Wheels: Campagnolo WTO 45.
Tyres: Veloflex Corsa EVO TLR 28mm.
Cockpit: Colnago SR9 Stem 110mm with computer mount + Deda Superleggera 44cm.
Saddle: fi’zi:k Antares Versus Evo 00 Adaptive 139mm.
Pedals: Look Kéo Blade Carbon Ceramic Ti 16Nm.
Bottle Cages: Tacx Ciro.
Bar tape: fi’zi:k Microtex Vento 2mm Tacky.
It's all downhill from here, except for the uphills.
MrCurrieinahurry
by MrCurrieinahurry
Dang she's gorgeous how was the ride then?
Basso Diamante super record EPS 12
BMC slr01 ultegra Di2
ConfusedRob
by ConfusedRob
Stunning! What did the final weight come in at?
spokenwords
by spokenwords
Its nice to see a paint job like that. So many matte bikes these days.
"Notice how the door closes when the chimes of freedom ring." Joe Strummer
"this goes to 11" Nigel Tufnel
Dont move to Austin
fogman
by fogman
ConfusedRob wrote:Stunning! What did the final weight come in at?
Finally got around to weighing the V3Rs. It is 7.43 kg (16.38 lbs) according to my Feedback Sports scale.
fogman
by fogman
I guess this could have been prevented by not riding my bike Image. Although the paint does seem a bit more fragile than other frames I have owned.
bikeboy1tr
by bikeboy1tr
Riding buddies of mine have owned past Colnagos have said that the paint is so thick that it becomes briddle and chips easily. I dont know if that is still the case or not wouldnt surprise me. Both my V2R have very few chips and I am not that delicate with my bikes.
viewtopic.php?f=10&t=154188
2018 Colnago V2R Rim Brake
2019 Colnago V2R Disc Brake
Fideliojbc
by Fideliojbc
Why a 44 cm handlebar in a 50s size? Just curious
fogman
by fogman
Deda measures outside-to-outside. So a Deda 44 cm is similar to a 42 cm center-to-center handlebar, which is how most other brands measure.
Handlebar width is independent of frame size. I use the handlebar size that maximizes comfort for my fit. Cyclists with wider shoulders generally use wider bars, unless you wish to sacrifice comfort for aero.
Fideliojbc
by Fideliojbc
fogman wrote:Deda measures outside-to-outside. So a Deda 44 cm is similar to a 42 cm center-to-center handlebar, which is how most other brands measure.
Thanks. I am about to order a Deda Superzero and did not know the way they measure.
fogman
by fogman
Before and after. I am very pleased with the paint repair. Can’t tell it was ever touched up.
MarcFaFo
by MarcFaFo
WoW has this been done locally or did you sent is back to Italy?
fogman
by fogman
@MarcFaFo, the paint repair was done by a carbon repair & custom paint company located in the US. Currently, the bike is being reassembled at my LBS.
