Gravel Tire Pressure
MikeD
by MikeD
As I was riding my gravel bike on a bumpy gravel road the other day, and getting beat up because of the rough road, I realized I should have used much less tire pressure. I set my pressure using a spreadsheet that goes by 15 percent tire drop. This works great for pavement but not off road. Any recommendations here or a recommended calculator based on tire width and weight? Also, the ride was about 1/3 dirt and 2/3 pavement. Obviously, I wouldn't want to have underinflated tires on pavement either. Guess I need to carry a pressure gage too for these types of rides so I can let pressure out or pump up.
kervelo
by kervelo
MikeD wrote:
Mon Apr 19, 2021 3:08 pm
... recommendations here or a recommended calculator based on tire width and weight?
SRAM calculator is good.
https://axs.sram.com/guides/tire/pressure
Singular
by Singular
I really like the Silca pressure calculator; https://info.silca.cc/silca-professiona ... calculator
MikeD
by MikeD
That looks like a good calculator. Thanks.
pdlpsher1
by pdlpsher1
I run 30psi/35psi F/R for 650Bx40 with 80% gravel. I ran the Sram calculator and it gave me 32psi/34psi F/R. That's pretty close. I generally like to run quite a bit lower pressure on the front since when I wash out on loose gravel it's always the front tire that goes first.
MikeD
by MikeD
pdlpsher1 wrote:I run 30psi/35psi F/R for 650Bx40 with 80% gravel. I ran the Sram calculator and it gave me 32psi/34psi F/R. That's pretty close. I generally like to run quite a bit lower pressure on the front since when I wash out on loose gravel it's always the front tire that goes first.
The SRAM calculator must assume a front/rear weight distribution; probably 55/45. It would be nice to be able to plug in your own numbers for this, but that's a minor nit pick.
Also, it says to use the labeled tire width. Shouldn't that be the actual, measured width? As everyone knows, the labeled width can vary significantly from the actual width.
tritiltheend
by tritiltheend
I prefer the Silca calculator to the SRAM one, it gives more granular results and as someone else pointed out, the distinction between measured and labelled width is very important. But in my limited use of the SRAM one it gave fairly similar results. While it's possible to go too low, I think a lot of people err on the side of overly high pressure - old habits die hard. I use the "Category IV" setting for most of my gravel riding, which often involves easier MTB trails, and only go higher if I know that the gravel is going to be smooth and I'm riding a lot of pavement.
MikeD
by MikeD
tritiltheend wrote:I prefer the Silca calculator to the SRAM one, it gives more granular results and as someone else pointed out, the distinction between measured and labelled width is very important. But in my limited use of the SRAM one it gave fairly similar results. While it's possible to go too low, I think a lot of people err on the side of overly high pressure - old habits die hard. I use the "Category IV" setting for most of my gravel riding, which often involves easier MTB trails, and only go higher if I know that the gravel is going to be smooth and I'm riding a lot of pavement.
The Silca one is nice. I like the selections for surface condition and weight distribution.
Marin
by Marin
For road & gravel: Deflate the front tire until you get understeer when braking hard into turns, then add 0.1 bar. Rear tire pressure a little higher.
For mostly gravel on tubeless: Deflate until you get *slight* hits to the rim in the roughest sections. Brake a bit earlier for turns on asphalt.
You're NOT losing any speed running the tires soft on the road!
ms6073
by ms6073
Marin wrote:
Wed Apr 21, 2021 12:47 pm
Isn' that somewhat antithetical given that on the harder road surfaces, aren't under inflated tires going to have higher rolling resistance?
Now I am the last person to preach about being OCD about things like tire pressure, but back in my cross racing days, 'proper' tire pressure was derived from a process of sucessive trial and error rides while adding/remiving air until the appropriate level of performance was achiived. From this, multuple baselines were established for varying conditions as tire pressure for racing on a dry day on a long, mostly grass course could vary quite a bit from the lower pressures used to race on a highly technical mixed surface course on a cold, wet/muddy day.
- Michael
"Solving problems you didn't know you had in ways you probably won't understand"
tanhalt
by tanhalt
Well...actually, you are...but " 'Tis far better to err on the side of too low of pressure than too high"
Travelbytaco
by Travelbytaco
Just tried the Silca calculator and it's spot on to what I run; 40psi, f/r.
Js2
by Js2
I used to run 32-35 but the grip was not good under braking. Based on the Silca Calculator it shoots out 40 psi for me, but that's way too high in my experience.
Off-road on 40c tires (42mm measured) Pirelli Gravel M I run 27 psi front 30 psi rear. I weigh about 140 lbs with a 20 lbs bike. Add 2 bottles and a saddlebag.
Planning to run 45 Gravel M up front when the 40c wears out to drop the pressure even more.
tjvirden
by tjvirden
ms6073 wrote:
Wed Apr 21, 2021 3:37 pm
This sounds far too practical! Follow this and there's a danger everyone will get to the correct pressure for them and their riding; still, plenty would continue to insist that "their" pressure was the correct one....for everyone else :wink:
