Sram Rival AXS
gSporco
by gSporco
Any grease that's no corrosive to Aluminum, Plastic, Carbon or Steel is acceptable for use on our bikes.. Typically you want to choose something with a Poly blend, as oil based lubes can be corrosive and have adverse interactions with component materials..
@gSporco - Instagram
Specialized Aethos - Evolving build
Niner RLT 9 Alloy - Stable Mable
Specialized Chisel - Dirty Derick
Retired Cervelo Aspero
Eterna7m
by Eterna7m
Has anyone used both SRAM force and rival axs and can tell me.whether they've missed the bite point adjustment?
DaveS
by DaveS
Rival has no contact point adjustment, just lever reach.
pmprego
by pmprego
DaveS wrote:
Fri Oct 01, 2021 5:07 pm
I guess that's what he's asking. If people miss that feature from rival groupset. I'm assuming to decide to go for rival or force.
Eterna7m
by Eterna7m
pmprego wrote:
Fri Oct 01, 2021 5:15 pm
Sorry I've didn't think mentioning it again was necessary and kinda self explanatory from context.
But yeah, I'm on the fence between these two.
On my current bike I can push the lever to the bars and I'd like to avoid that with my new bike (semi hydro + Shimano)
zik
by zik
do you know if sram olive and bard can be reused, I need to shorten brake cable ?
gSporco
by gSporco
zik wrote:
Fri Oct 01, 2021 7:20 pm
No, once its crimped on when screwed into the shifter or caliper it crimps the the okive and barb amd makes it extremely difficult to remove the olive.. if somehow you are able to separate them, you could use the barb again as its hard stainless steel and doesn't deform... but its kinda pointless as these pieces are sold in sets and you will just be left with extra barbs at the end of the day
robbosmans
by robbosmans
And your lbs probably has hundreds of them laying around, they wouldn’t mind missing a pair
nismosr
by nismosr
does anyone know where to get a 1x groupset ?
2020 Colnago C64 Mapei - Campagnolo SR12 EPS - Campagnolo Bora WTO 60
2020 Basso Diamante - Campagnolo SR11 EPS - LW Meilenstein
2021 Basso Diamante SV - Campagnolo SR12 EPS - Fulcrum Wind 55
Boxxy
by Boxxy
Is it possible to use force etap levers with rival etap fd/rd? Then I could use rim brakes with rival. Been searching for the answer everywhere with no luck
robbosmans
by robbosmans
Yeah no problem, everything AXS is compatible with each other
Boxxy
by Boxxy
robbosmans wrote:
Fri Oct 29, 2021 7:19 pm
woohoo thank you so much, that is very good news :D
g32ecs
by g32ecs
JMeinholdt wrote:
Fri Apr 23, 2021 3:19 am
TobinHatesYou wrote:
Fri Apr 23, 2021 1:16 am
DaveS wrote:
Fri Apr 23, 2021 12:57 am
Good to know. If the longevity is similar, it's a bargain. I haven't seen any info about rotors, whether included with the shifters and calipers.
Actually I misread. ~15g heavier for the FD, ~60g heavier for the RD.
If piecemealing a mixed bang for the buck group together I would likely go with at least the Force RD (better clutch,) Rival FD, Rival shifters/calipers, Red cranks, 4-bolt spider+chainrings, Red cassette, Rival chain, Centerline X rotors.
I think you're right on the money as far as value to weight ratio is concerned with this build. When I built my Force group up it was clear that the cranks and cassette are by far the best way to save weight on an AXS build.
Im looking to do a build and was thinking going Force for FD/RD/shifters, Red for cranks and Rival chain/calipers and cassette for high wearing parts.
I dont think I could afford the Force or Red cassette and chain in the long run especially when Shimano and SRAM are divorcing with compatibility. This sucks for us consumers. Has any 3rd party company made any AXS parts?
gSporco
by gSporco
g32ecs wrote:
Fri Oct 29, 2021 8:11 pm
I think the best Price to weight ratio for AXS is as follows:
Rival Shifters
Rival FD (nearly as lite as Red and lighter than Force)
Force RD
Force cassette (Rival cassette is really heavy)
Red Crank arms (cant beat 355g arms)
Chain Rings Red or Force, whatever is cheaper, they are really close in weight
Chain Force chain is pretty good for $35 USD
itapersita
by itapersita
gSporco wrote:
Sat Oct 30, 2021 1:36 am
Rival Shifters
Force RD
I quote your post because I am in the middle of a crisis here :lol:
I bought a aspero frame 1 y ago and very slowly I am building my bike. At the moment I have a For e RD, Red crank arms, chainrings .... almost done the transmission except for the shifters and brakes. I wanted to go for the Force but it is almost impossible to find. Now the rival shifters are available somewhere and I don't know what to do: waiting for the for e.or go for the rival? It's mainly a psychological thing, my dream was to build this bike with premium components and I did not want to go for "budget" stuff.
