Light, Durable ~30mm inner rims?
Casio20
by Casio20
Hi dear Friends,
I'm looking forward to a new wheelset for my gravelbike with 30mm internals and came across these two rims which are very interesting.
These two rims in T800 looks super light and with the same weight with 320g. The 28mm depth rim is maybe even a bit more aerodynamic without a wieght penalty.
Can you please share your thoughts.
Thanks a lot :)
LeDuke
by LeDuke
I'd go with something deeper, but that's just me.
The new Nextie super wide gravel rims are pretty interesting:
https://www.nextie.com/gravel-AGX-700C-NXT36AGX
LeDuke
by LeDuke
Duplicate post. Sorry.
mergeforthekill
by mergeforthekill
Has anyone tested real world weights for the EIE wheel builds. Im skeptical on the weight their online wheel builder tool is quoting for a 27mm internal 28/28 DT350 build. Dont get me wrong, id be plenty happy if it did match up with the 1350g's-ish quote but seems far fetched.
LeDuke
by LeDuke
Use their rim weights and ERDs in the DT Swiss spoke calculator. It’s quite accurate. My wife’s EIE/350 build was within a gram or two of what DT predicted, using known (within a couple grams of advertised) weights of the rims.
la85
by la85
mergeforthekill wrote:
Tue Jun 22, 2021 11:26 pm
I got a set of EIE wheels, built by EIE.
I went the following:
A29C25D22 Wheels SL:310+/-15G,UD,Matte ,32H ,black eie decals )--2pcs Hubs:Chosen lefty 2.0 front ,DT Swiss 240 exp 12*148 32H 6-BOLT SRAM XD ,54T,j-BEND (Rear wheels needs to be dished 6mm for Cannodale AI) Spoke:Sapim CX-Ray Nipple
They weighed 1300 grams for the set without valves and tape.
mergeforthekill
by mergeforthekill
Awesome, thanks for the info!
MARC0
by MARC0
Casio20 wrote:Hi dear Friends,
Thanks a lot :)
Take the second one to be combined with sapim MG washers to be more accurate with the spokes tension.
njyeti
by njyeti
Any opinion on the Tune Blackburner 28 Endurance? Seems like a reasonable/safe weight (and is even 32 spoke). https://r2-bike.com/TUNE-Wheelset-29-Bl ... -Thru-Axle
Another thought is the new Schmolke TLO XC rims with Carbon Ti. Similar weight, but more narrow ID and taller rims. https://r2-bike.com/Wheelset-29-XC-Carb ... arbon-Rims
I'll be using this on my XC race hardtail. Thanks all!
LeDuke
by LeDuke
Not great weights for very high prices.
I’d go with the new Duke Crazy Jack SLS3, Berd and hubs of your choice. Cheaper, wider, lighter.
njyeti
by njyeti
Those rims are nice and light for the width & claimed durability. Thanks @LeDuke.
LeDuke
by LeDuke
My wheels arrived today. 1315g; will drop 10g with the XD freehub.
F45
by F45
Too bad you got those DT EXP hubs. Problematic.
LeDuke
by LeDuke
F45 wrote:Too bad you got those DT EXP hubs. Problematic.
Exchanged the ratchet before I sent them off to be built. Flawless performance.
sigma
by sigma
LeDuke wrote:
Mon Mar 29, 2021 3:22 pm
Has anyone seen scale shots of the 2020+ DT Swiss XRC 1200 Spline 30s with 180s?
Or the XMCs with the new 180s?
The listed weights and the weights posted on various retailer websites are all over the place.
Curious which way you went as I am also contemplating a 30mm inner width build for a new MTB frame coming in. Probaly also doing similar rides but in UT.
S-works Tarmac SL6
S-works Tarmac SL7
S-Works Venge
S-Works Roubaix
Factor VAM 02 disc
Factor One rim v2
Factor LS
Cannondale Black Inc Scalpel 2017
Cannondale Scalpel SE LTD 2021
