Syntace Flatforce 55/66 actual lengths?
016XC
by 016XC
Hello,
Any Flatforce owners here?
I need to get my bar lower, and Flatforce seems to be the best tool for the job.
I would like to keep the current reach about the same, and I'm currently using Bontrager Potence -17degrees/75mm stem.
I have read from previous topics that the sizing is a little different. I also contacted Syntace about it, but they didnt provide any real measurements.
What is the length center-to-center measured from the top in 55 or 66 models?
Thanks
grover
by grover
I have a Flatforce99. The 99 measure seems to be from the front of the steerer clamp to the centre of the bar clamp. So add half the width of a steerer, ~15mm.
Kristinka
by Kristinka
Check also FSA SL-K and NS -20°stems. They are very similar to Syntace Flatforce. Though made in different lenghts.
https://shop.fullspeedahead.com/en/type ... -drop-stem
Malutkiz
by Malutkiz
You can also look for Token TK9320
Wysłane z mojego Redmi Note 8T przy użyciu Tapatalka
