Building an XCR CX/Gravel
DHG01
by DHG01
Beautiful day in Madrid for a test ride. I did something short; about 40 km. A bit of single track, gravel, rougher gravel and abandoned tarmac.
I had two of the classic mechanicals; bottle cage was loose and seatpost slipped. I ve now removed 1 cm of spacer.
But truth is I am delighted! Very, very pleased. Geometry is perfect (as you would expect). The ride is very similar to a good titanium; it has that springly feeling when going over rough terrain (unlike the Standert). The bridge on the seat stays is very thin; perhaps that and the flattened top tube contribute to the ride. Down tube is bi axial and shaped (not round); looks really good.
Lower bottom bracket (than a typical CX) and a relatively contained wheelbase, keep it agile on the single tracks. HT angle at 71.5 is fine; I do wonder what would have happened with the BMCs 72.5.
Still need to ride more, but I think it is a very good balance between sporty and comfy frame.
Mini motos brake fine; actually, as long as I keep those rims and pads together, and it is dry, braking is superb. But they are a bit of pain to setup. Cable is compressionless.
I found Red a bit more mechanical, less smoother than usual. Perhaps cabling needs to settle in.
3T wheelset is a good balance between light and stiff. They probable weigh 200/250 grams more than the 2.2 SES I initially got for this bike, but the Enve s lack stiffness. As I ve written before, I don't need the stiffness to transfer loads of power, but to provide a more composed behavior. When tyres slip and we have to react, we don't need wobbly tyres to make things worse.
Sammy Slick tubulars have been a very pleasant surprise; particulary being used to Vittoria and Challenge. Pumped at 3 bar/45 PSI, good grip on dry hard pack, nice soft rubber and smooth ride (particularly compared to Tufos).
And that is about it. I will update the final weights.
Highly recommend Pablo from BBloque; excellent craftsmanship and attention to detail. At €1800 frame/€350 paint, I am thinking of getting road version.
I hope sharing my experience has been of some use.
DHG01
by DHG01
First day in the wet. Not the best tyres for grip on mud, but the ride was still fine.
It is a very pleasant surprise to see how látex tubulars (or tubeless for that matter) and a compliant frame allow to roll comfortably through gravel yet at 33 mm width and 3 bar are not too bad when connecting paths on tarmac.
DHG01
by DHG01
Ahead of an event 2 weeks back.
I swapped the carbon post for a titanium one. I think it looks better, but open to other views. Comfort wise, I haven't noticed anything. I guess straight and little seat post sticking out is the reason. Also, carbon rails on the saddle might also have something to do with it.
stanvr
by stanvr
I like the titanium post! A ti stem would go well with it too I think, similar to your chrome Standert and Klein used to be ;).
DHG01
by DHG01
stanvr wrote:
Sat Mar 20, 2021 11:47 am
Thank you my friend. I might be abusing too much of the chrome look?!?
I see the Klein is looking more beautiful every day!
stanvr
by stanvr
Yeah I wouldn't go for more chrome looky bikes personally, but hey, it's titanium and thats cool! Definitely more special over carbon/black parts:)
DHG01
by DHG01
I a bit of an update.
Long ride beside a canal in Valladolid; nice flat gravel ride, perfect weather and company of a good friend.
A few learnings.
Early flat on new Challenge Almanzo tubular (yeah...I know, tubeless). I didn't have enough sealant to fix; I looked ahead of the ride, but the bubbly nature of the Effetto Mariposa made me think the bottle was full.
So I had to put on the spare Tufo. Second learning, off go the J&L titanium skewers. They are very light and no stiffness or safety issues, but the aluminium allen bolt (alternative to QR handle) slipped when trying to unbolt. Only because I was fortunate enough to find someone with pliers (and flatted 500 m from a small town, instead of 12km) was I able to release the rear wheel. I won't put back the original 3T, but will find a lights and suitable alternative. BTW, my tubeless fanboy buddy was impressed on how to swap a tubular in 3 min (spare was obviously stretched already).
Third learning; on these shallowish wheels, some tubulars require valve extenders other do not. Fortunately the Tufo doesn't (the front Schwalbe does). If I would have been mounting 2 tubulars that do not requiere extender and the spare did, I would have had another problem - learning; carrying a valve extender going forward.
Delicious ride; the bike rides like a dream, comfy road geometry and flexy back end due to the steel and the build.
DHG01
by DHG01
Forgot - 60 grams saved by reducing titanium seat post length.
