How wide are those Conti's on those rims? WR50 is 32mm right?
Cervelo R5 Disc (6.5kg)
Can I ask where you got the Garmin Radar mount from, and does it work well with your Berk?
Cannondale SSEvo3 'Atticus' - 7.2kg
viewtopic.php?f=10&t=161634
Cannondale Systemsix ’Dante’ - 7.7kg
viewtopic.php?f=10&t=167144
Its 3d printed.Jackofallgrades wrote:Can I ask where you got the Garmin Radar mount from, and does it work well with your Berk?
It works great.
https://www.thingiverse.com/thing:4458136
My cages are Chinese, I got them from Ali Express for like $30 each. I haven't had any issues and I've had them for over a year now.da123 wrote:Lovely build.
Interested to know how you find the carbonworks copy bottle cages? Can you post a link if they're any good?
Cheers, Dave
https://a.aliexpress.com/_mrhgXE6
Its perfect.drumjdds wrote:fantastic build! do you see any areas for upgrades or is it already pretty close to perfect?
I can save more weight by either reducing functionality or spending hundreds of dollars but I rather spend my money on other stuff.
Local Cervélo dealer. They had to make a special order from their rep.
Are you sure those are the CW copy cages? I have those ones in your link and they are a different design. Specifically, there is an upper and lower arm on these cages vs the CW cages which only have a lower arm. Also the CW cages have a wider mouth. I have the cages in your link (not the CW copies) and they aren't so great at holding Elite Fly bottles. Podiums are a better fit but still not super secure.Aryeh wrote: ↑Tue Apr 05, 2022 5:47 pmMy cages are Chinese, I got them from Ali Express for like $30 each. I haven't had any issues and I've had them for over a year now.da123 wrote:Lovely build.
Cheers, Dave
My lower arms broke off from heavy insulated podium bottles. Now I use non insulated Elite bottles and I never had a bottle fall out in 2 years.iamraymond wrote:Are you sure those are the CW copy cages? I have those ones in your link and they are a different design. Specifically, there is an upper and lower arm on these cages vs the CW cages which only have a lower arm. Also the CW cages have a wider mouth. I have the cages in your link (not the CW copies) and they aren't so great at holding Elite Fly bottles. Podiums are a better fit but still not super secure.Aryeh wrote: ↑Tue Apr 05, 2022 5:47 pmMy cages are Chinese, I got them from Ali Express for like $30 each. I haven't had any issues and I've had them for over a year now.da123 wrote:Lovely build.
Cheers, Dave
They must have changed the design.
