Factor Ostro
ArtV
by ArtV
Thanks. I already did some investigation and the rattle happens when I turn the bars and I was able to 'hook' the cable through the bottle cage bolt opening and it stops. With that I am pretty sure it is rattling in the downtube (think that is the correct term).
Hope I am correct and can resolve this without resorting to replacing the brake lines. Love the look of integrated cables but they can be a pain.
kode54
by kode54
Sounds like it was assembled without the foam dampener. You'll have to stuff some foam in the downtube or try to wrap foam on the cables through the headset area. At home improvement stores, they sell a foam with a slice along the edge so you can wrap it around an existing pipe...and along the edges, there's adhesive. Might be your best bet.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
ArtV
by ArtV
Well, I am all set with three types of foam:
Jagwire which is about the size of the cable
Pipe insulation (from a hardware store)
And don't laugh........ a pool noodle. Color perfectly matches the Flickr blue. :-)
I am thinking the pipe insulation is going to be the best bet. I could see the Jagwire stuff still smacking against the inner wall of the frame but I really won't know until I try. The pool noodle looks too big.
Art
Sent from my SM-T860 using Tapatalk
kode54
by kode54
Jagwire when installing since it is a bit narrow. You'll need to take the hoses off and thread it through the foam.
Pipe insulation is what I used to use several years back. A bit heavier because of the bulk, but I.D. is large enough to put (at the time) Di2 wire and hydraulic hose together. You just need something between the frame and the hose anyway you can.
- Factor LS Disc
ArtV
by ArtV
Done. It wasn't TOO terribly difficult. I mean I didn't cuss or cut my hands so how bad could it have been?
I went with the foam pipe insulation.
ArtV
inertianinja
by inertianinja
Has anyone used a non-BlackInc handlebar with the Ostro?
I have the barstem, but it's about 7mm longer than my usual, and I am thinking of switching if possible.
kode54
by kode54
Someone asked about that on pg 65 regarding a S-Works stem. I'm curious about this as well, both stem and handlebar with internal hydro hose routing.
- Factor LS Disc
MysticRiver
by MysticRiver
Does the Solid lube techonology in the headset bearings change the feel drastically? I've been told by a couple people that my headset is too tight and I should loosen it and not sure whether the bearings just feel different than standard bearings or if the headset was overtightened when the bike was assemebled...
MysticRiver
by MysticRiver
New barstem highlighted by cycling tips towards the end of https://cyclingtips.com/2022/07/tour-de ... oad-stage/
Also Mike Woods using a Darimo seatpost
Conradsleight
by Conradsleight
MysticRiver wrote:
Sun Jul 03, 2022 6:13 pm
Curious when they will release this. Presumably soon given they're using it. Have my new bike coming next month and would be nice to have the latest.
bruno2000
by bruno2000
If I buy an Ostro frame without the integrated handlebar, will I be able to use any stem I want?
Do you know of the frame is provided with a 'non-integrated' topcap for the headset?
mathias720
by mathias720
did anyone find a Direct mount hanger other than from factor them self? or did anyone find a supplier in europe having them in stock ?
will be crazy expensive with tax and shipping from US or HK. so hoping to find one in europe.
mathias720
by mathias720
bruno2000 wrote:
Tue Jul 05, 2022 11:17 am
The integrated handlebar/stem is part of the frameset package.
but you can use regular stem/handlebars as long as there is holes for cables to run on the inside. dont need any other topcap or anything.
MysticRiver
by MysticRiver
mathias720 wrote:
Wed Jul 06, 2022 10:12 am
I was not able to find one but would love to...
kode54
by kode54
Factor quoted $75 for their version. Wasn't that much when I bought one from them for the O2 VAM (same DM hanger)...probably around half that back then.
- Factor LS Disc
