Factor Ostro
So i here is a complete parts list of mine.
i am racing my bike so have to stay above the 6.8kg limit, but i am constantly trying to find the most aero solutions and still keeping it at 6.8kg. i have a lightweight setup with light wheels,cassette and chainrings for the alps that gets me to around 6.2kg
You managed to get an exs bar/stem?mathias720 wrote:So i here is a complete parts list of mine.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
- Factor LS Disc
I typically change all my bolts to titanium regardless, since I ride in wet/damp/rain conditions several times (Northeast US) that can’t be avoided. Also, most manufacturers, when using Ti bolts use silver/raw colored. I change then to black including the M3x5mm countersunk ones for the Garmin mounting adapter. Yes, some bolts in the bike were Ti to begin with.MysticRiver wrote:kode54 wrote: ↑Mon Nov 21, 2022 11:59 amI have the newer light Enve 6.7 on and they’re about 1400g plus or minus. Saving 400g is definitely close to a pound (US .88lb) but can’t see saving anymore weight in my end.
All bolts are now titanium.
Frame size 52cm
Matte clear no other paint
Darimo 15mm setback post
THM Clavicula SE cranks
Carbon-Ti chainrings
Dulight Tuned Wahoo Titanium pedals
Berk Lupina saddle
Conti GP5000s TR 28mm tires
Black Inc 380 /110mm integrated bars
DA 9270 group
Hambini BB
Enve 6.7 wheels Chris King hubs
Lupine Neo bike light (battery off at weighing)
Even with these parts, I’m at 7.24kg
Which of the stock bolts aren't titanium? How much weight savings is replacing all of them get you?
- Factor LS Disc
- Factor LS Disc
I have the porkier molded in expander. My former steerer is cut at the top using the 20mm spacer plus one 5mm one and the stem adapter. The fork I have probably weighs more than cyclespeed’s for that reason.cyclespeed wrote:I'm on DA 9270 12 speed (11-30 cassette).
My frame weighs 824g, (Flickr no paint) and the fork got lighter when they swapped it for the nutset model.
Plus, I weighed mine RTR with all bits on like pedals. Only exception is water bottles and Karoo2. No saddle bags since I carry minimal tools and CO2 is jersey pocket.
Best to try another scale like it was suggested.
- Factor LS Disc
- Factor LS Disc
My O2 VAM disc was at 6.83kg. 52cm size as well. Although I had Darimo post, bar (38cm) and stem (120mm) that were lighter so I didn’t question the extra weight due to heavier deep wheels and Black Inc integrated barstem (heavier than Darimo combo). Plus, 11-speed on O2 VAM vs. 12-speed on Ostro.mrlobber wrote:We pretty much know that the Ostro likely has gone slightly heavier over the lifecycle of the model, as Factor have themselves admitted they make silent running changes (which, of course, is actually good).
Cyclespeed's Ostro, if I understand correctly, has 11 speed DA with 9270 calipers, so he could save 50+ g on a cassette (Red 1190) vs 12 speed DA right away, compared to kode54.
Also, FWIW, I've got an O2 VAM size 56 on 11 speed DA as well, hovering around 6kg with 1100g tubular wheels, subtracting 150g on wheels (plus cyclespeed's Ostro was 52, I think?), would net me around 5.8...5.85kg, the difference of 100 or so grams looks to be about right comparing O2 VAM vs Ostro frameset,
I’m not all that concerned about the weight since I have an Aethos for climbing days. I was just wondering where I am gaining weight where cycle speed is 5.95kg.
- Factor LS Disc
- Factor LS Disc
Should arrivive at my door this weekkode54 wrote: ↑Wed Nov 23, 2022 11:12 amYou managed to get an exs bar/stem?mathias720 wrote:So i here is a complete parts list of mine.
Did you order direct from China?
I didn’t think they were selling outside China until they caught up with orders there, let alone international sales. Maybe C100?
- Factor LS Disc
- Factor LS Disc
i have a great contact in china that made it happen.
quite exciting to see the weight, and alos how it is to ride the 36cm width
- cyclespeed
The Ostro fork is a work of art....
I have to get a new scale. 6.7kg is light for parts mentioned. I have no PM…THM Clavicula SE w Carbon-Ti chainrings. Maybe I used too much sealant in my tires. LOLpipii wrote:Should be around 6.7kg as estimated with 8070 and wheels not that light.Still one or two weeks to wait for perfect setup.
- Factor LS Disc
- Factor LS Disc
Hello,kode54 wrote: ↑Tue Nov 29, 2022 2:01 pmI have to get a new scale. 6.7kg is light for parts mentioned. I have no PM…THM Clavicula SE w Carbon-Ti chainrings. Maybe I used too much sealant in my tires. LOLpipii wrote:Should be around 6.7kg as estimated with 8070 and wheels not that light.Still one or two weeks to wait for perfect setup.
I have a Factor Ostro VAM and I would like to install my THM Clavicula SE on it. Would it work with the stock bottom bracket? Is there anything specific to know to properly install it? Thanks in advance.
When you’re saying stock Factor bottom bracket? If so, the answer is yes. Should work with no issues. A thin .5mm on DS is recommended by THM.
I have a Hambini in mine.
- Factor LS Disc
- Factor LS Disc
