Specialized S-Works Tarmac SL6 Ultralight 6,16kg
ome rodriguez
by ome rodriguez
Build list
FRAME: Specialized S-Works Tarmac SL6 Ultralight
PARTS:
- DRIVETRAIN: Campagnolo Record 12 speed mechanical
- CRANKSET: Sram Red true BB30 with Praxis Works Buzz Chainrings
- PEDALS: Shimano Dura-Ace 9100
- BRAKES: eeBrakes
- WHEELSET: Lightweight Meilenstein C 20C Carbon Clinchers
- TIRES: Continental GP5000
- CASSETTE: Recon one piece Cr-Mo cassette Campagnolo 12S
- SADDLE: Specialized S-Works Power
- STEM: Mcfk Carbon
- HANDLEBAR: Easton EC90 SLX
- BOTTLECAGE: Ax-lightness Nasdorowje Carbon
I know it's just another Tarmac, but its a foolproof race bike. Its been with me for almost 3 years now. I'm enjoying discbrakes at the moment, but this is still my go to bike. This might be the last rimbrake Tarmac so will just keep it.
Thanks again for looking.
Last edited by ome rodriguez on Thu Jun 18, 2020 10:45 pm, edited 1 time in total.
NiFTY
by NiFTY
Great bike but please removal the awful sticker that says to look at the manual.
dgasmd
by dgasmd
I’m baffled by your choice of Campagnolo with an SRAM crank? What’s the logic? And how smooth is it and the shifting quality?
stevec1975
by stevec1975
Great bike, curious on the Sram/Campag mix but each to their own!, I can't get past the bar tape wrap behind the shifters though..
ome rodriguez
by ome rodriguez
NiFTY wrote:
Thu Jun 18, 2020 11:03 am
Hahaha will do that. Thanks.
ome rodriguez
by ome rodriguez
dgasmd wrote:
Thu Jun 18, 2020 2:15 pm
I wanted a true bb30 crankset so I can use the ceramicspeed bb30 bearings that came with the frame without using adaptors and spacers. I'm a campy user, but didn't mind using sram cranks on this build and lighter too. The shifting quality is on par to my other bike with full campy drivetrain.
ome rodriguez
by ome rodriguez
stevec1975 wrote:
Thu Jun 18, 2020 2:31 pm
Thanks. I see a lot of Shimano/Sram mix and Shimano/Campagnolo mix, doesn't really bother me as long it works well and can save weight.
ome rodriguez
by ome rodriguez
Thinking of upgrading the stock seatpost to a Darimo T1 Loop Aero Seatpost for Specialized Tarmac, could save another 100g.
ome rodriguez
by ome rodriguez
My bartape got short didn't put the small strip of bar tape wrap behind the shifter clamps, won't miss that next time when I replace with new ones.
Seedster
by Seedster
Great weight on your build!
Praxis chainrings are the best non-campy rings I have used on a campy electronic drivetrain. That said, I found the weight sacrifice, shifting and aesthetics worth it by going with a campy crankset.
FredBloggs
by FredBloggs
Do yourself a favour and learn how to wrap bar tape properly, i.e. without the small 3" piece of tape which manufactures supply. See here for a link on how to wrap 👍🏻
https://vimeo.com/25097893
ome rodriguez
by ome rodriguez
FredBloggs wrote:
Tue Jun 23, 2020 8:53 am
Thanks for the link, but I prefer the one pass.
Luften
by Luften
What are your thoguhts on the MCFK stem? Any comparisons to how it feels versus the stock S-Works stem?
mendiz
by mendiz
And I add thoughts between Mcfk stem vs Ax Lightness stem?
You don´t stop riding when you get old, you get old when you stop riding.
ome rodriguez
by ome rodriguez
mendiz wrote:
Sun Aug 16, 2020 7:43 pm
Luften wrote:
Sat Aug 15, 2020 10:24 pm
Haven't tried s-works stem. I used deda superleggero stem before, didn't notice any flex when using mcfk and ax-lightness. Both are stiff enough for me. But tried the darimo and can feel it flex.
