New Exploro RaceMax
stalkersk
by stalkersk
Not entirely true, you can use apto integrale stem with spacer on top, but you need to have bars with opening in the middle, where you can run 2 hoses
Upcountry
by Upcountry
stalkersk wrote:
Tue Oct 17, 2023 8:32 pm
No, you can't... The stem fits entirely over the top of a cut steerer tube...
Upcountry
by Upcountry
Ahh... Didn't read into the Apto part, but still thinking thats a no... The bike we're discussing has a new, and very distinctly shaped, steerer... I don't see them mentioning anything other than the More integrale stem, which they include with each build option.
stalkersk
by stalkersk
Look the strada and exploro use same headset and also stems. The headset uses D-shaped compression ring. So in the end you are searching for problems which do not exist :)
He's got new Exploro Italia with Apto stem.
https://www.instagram.com/reel/CxlS6TNs ... BiNWFlZA==
aldoxzx
by aldoxzx
Josku wrote:
Mon Oct 16, 2023 7:26 pm
saverin wrote:Anyone run into chainsuck issues with SRAM 2x (AXS, non-wide)?
Running a 46/33 Force D1 crankset with Rival FD and had chain work it's way between crankset and chainstay twice on last ride when shifting from big chainring to small chainring. Chain didn't drop, just have enough clearance for chain to make it's way between dropped chainstay and crankset. I suspect there was some buildup of thicker factory SRAM grease that contributed....but wondering if there's any setup tricks to address this on Exploro Race setups...
Had the same problem. The only solution was to go for 1x. Especially in rainy days it was impossible to ride in small chainring. I do know few other people who had the same problem.
When learning the problem, local bike shop refused to sell 2x setup. Other than RaceMax 3T gravel bikes should work fine with 2x.
Other than that I'm super happy about the bike. Image
I'm ready to buy a racemax with Force 2x and this is the only thing that is holding me back... is there really no solution to this? It seems like an issue that should be fixable somehow.
basurper
by basurper
I use ultegra di2 2x12. Have the same problem as well.
Sent from my SM-F731B using Tapatalk
saverin
by saverin
It's the nature of the position of the dropped chainstay relative to the chainrings - I'm pretty sure it's very sensitive to how sticky the chain lube you use is - once the factory SRAM grease wore off after a few cleans, seems to be getting better, but it's something to consider if you go with a 2x drivetrain and particularly on gravel. To the point where I wouldn't run 2x on gravel with this frame.
luisito10
by luisito10
Hi!
I'm super happy with my Racemax. Coming from a Grail AL, it feels and ride like a dream.
But last weekend, the front derailleur threw the chain into the frame, damaging the paint and maybe something else... It has happened when I change from the big chainring to the small one.
I noticed that the wedge between the front derailleur and the frame is not installed.
It is a Sram Force AXS 2x groupset.
Enviado desde mi GM1913 mediante Tapatalk
ghdana
by ghdana
I have an Ultra with a scratched BB area due to chaindrop as well(my fault, didn't wipe chain down for like 2 weeks of riding because it was bad conditions every day). It has scared me away from putting on a 44t chainring instead of a 42. Thinking I'll move to that eThirteen 9-52 cassette for more top end.
Rim Allez Sprint
3T Exploro Ultra
Speed of Light Tarmac SL7
aldoxzx
by aldoxzx
saverin wrote:
Tue Nov 14, 2023 5:10 pm
That's unfortunate.. going to look at something like the cervelo aspero now.
McSpins
by McSpins
This 2x issue is a huge bummer. The pics look like 2 different issues. The white bike shows it hitting the down tube on a front shift high to low. The blue bike seems to show more of a slap bounce from riding in a small inside chainring.
Has there been any response from 3T? Gerard doesn't have much love lost for front mechs, but if he didn't think it would work well I'd expect them to not support it (like the Open Wide, which uses a similar double drop chainstay).
I'd really like this to work because the stack/reach and geometry are exactly what I'm looking for. And would continue my long streak of vroomen designed bikes.
saverin
by saverin
Since we're on the topic of SRAM front derailleurs - which of the included FD support wedges are you using, if any?
Pictures of how/where you've installed would be greatly appreciated.
hannawald
by hannawald
This is a very nice bike, even more with the latest integrale option. It is appealing to have one bike for everything, but there are so many conflicting information. Some people say it is harsh for a road riding, some say it is OK. Some say it is twitchy even with 35C tires some say they ride 28C and it is OK. Really hard to guess what to expect using it mostly on the road with occational gravel use. My lbs owner uses Willier Rave SLR as a one bike for everything, former club racer and says he doesn´t see any limitations on this bike for road usage. I saw him riding the bike with gravel tires on forest paths full of tree roots and some stones, he was faster than me on an XC full suspension bike:)
spud
by spud
utlimately, you can adapt to any frame that is within reason, fit-wise. In any case, it's about balancing stack and reach, in combination with stem. IMHO, you can't set up a true gravel bike the same way you would set up a road bike - handlebars need to be a little higher and closer to you, in order to maintain proper (not excessive) front wheel loading, and give you more authority on lofting the front end over obstacles etc.
The bummer for me with 3T is they have no intention of selling intergrated forks for anyone on an older non-integrated 3T bike. They could have been nice to the their customers, but instead chose to try to force them to buy a new bike if hose integration is desired. They also don't offer in-frame storage, which is a shame, given the size of that downtube.
