Crux 2021
FactoryMatt
by FactoryMatt
you must use a 34.9mm Front Derailleur + the shim band that comes with the frame. they warn NOT to use a 31.8 FD directly on the frame.
23mm ID rim is fine. i run 22+ 38c tire, comes out to about 41mm width. max actual tire width is really about 40mm without rubbing when the rear tire/wheel flexes.
singletracknick
by singletracknick
FactoryMatt wrote:
Mon Nov 23, 2020 12:56 am
23mm ID rim is fine. i run 22+ 38c tire, comes out to about 41mm width. max tire size is really about 40mm without rubbing when the rear tire/wheel flexes.
Why is that?
I have a 31.8 der directly mounted and hasn't caused and issue?
FactoryMatt
by FactoryMatt
i don't know, but i suspect they're concerned about the clamp applying even pressure on the tube. mine came with a written notice in bold writing warning against doing so. the shim that comes with the frame is pretty elaborate.
samarskyrider
by samarskyrider
FactoryMatt wrote:i don't know, but i suspect they're concerned about the clamp applying even pressure on the tube. mine came with a written notice in bold writing warning against doing so. the shim that comes with the frame is pretty elaborate.
Is it specific shim or something that can be sourced w/o specialized dealer? If possible, please post pics
samarskyrider
by samarskyrider
FactoryMatt wrote:It looks like this.
https://www.amazon.com/FSA-Derailleur-S ... B0096XYQF2
Thank you!
gwerziou
by gwerziou
Is this FSA part directly usable on the Crux, or does it just resemble the actual shim that you need to use?
• A hi-zoot bike, pretty sweet
• An old bike, more fun than the new one actually
• Unicycle, no brand name visible
FactoryMatt
by FactoryMatt
gwerziou wrote:
Fri Dec 04, 2020 5:03 pm
it's directly usable. same piece.
Briscoelab
by Briscoelab
samarskyrider wrote:
Sun Nov 22, 2020 8:59 pm
Can anyone advise what size of clamp is needed for front derailleur?
Concerning the wheels, will it make sense to run 23mm ID rims on this frame?
I run both 21mm ID and 25mm ID rims. They both work fine. I have some 28mm road tires on the narrower wheel (Specialized C38) and 33mm Specialized Tracers on the 25mm Enve 3.4AR.
rothwem
by rothwem
How wide do the 33mm tracers blow up on your 25mm wheels?
I’ve got 38mm tracers on 19mm internal wheels, it seems like all the newer gravel stuff is super wide and the Crux doesn’t have a whole ton of space. I was thinking I’d have to drop down to 35s if I got a wide rim like that to fit in the frame.
FactoryMatt
by FactoryMatt
38 terrenos on 22mm internal hookless are fine. i run a little coke can taped inside of the chainstays for good measure.
there's no need for 25i rims on gravel tires IMO.
kppolich
by kppolich
15.75lbs with Enve CX Tubulars, XG1190 11-32 cassette, Zipp SL Speed post, stem, and SL70 carbon ergo bars. Love this bike, titanium spindles for the XTR pedals on the way.
FactoryMatt
by FactoryMatt
beautiful. where did you source the ti spindles? keep an eye on those ball-bearing races :)
samarskyrider
by samarskyrider
Looks clean
kppolich
by kppolich
FactoryMatt wrote:
Mon Jan 25, 2021 7:25 pm
I was willing to try these out. Picked up a pair for my Ultegra R8000 pedals as well.
https://titaniumplanet.com/en/products/ ... ength-_4mm
