Crux 2021
cerro
by cerro
srtlewis wrote:
Thu Dec 05, 2024 7:04 am
So Crux-ish question. I am in need of a new bb for my s-works crux. Love it do a fair amount of off road gravel and all road rides in all weather. Thinking of going with either Chris King steel or Kogel / c-bear ceramic w/ cross seals. Any opinions, experience or advice appreciated
Of those I would say Chris King. Got one for my Diverge 4 years ago. While changed bikes some times after that the bb is still going strong :)
josephtroppo
by josephtroppo
Now IF you're ok to spend extra on ceramic c-bear is great bang for buck.
I find it hard to justify the cost of ceramicspeed; however if cost weren't an issue I'd go for them.
joesch
by joesch
josephtroppo wrote:
Thu Dec 05, 2024 10:42 pm
+1 C-Bears are good value for money. They have a special CX/gravel version of their BB with improved sealing and different lubrication.
When I finally received my frameset, I was quite surprised to see it on the scale...my 56 10r frameset came out at 940g including the UDH adapter and seatpost clamp. I will remove both and reweigh the bare framesheet, but I cannot imagine that this will be the 115g difference from the claimed/specified weight.
joesch
by joesch
LanceLegstrong wrote:
Mon Nov 25, 2024 11:54 am
Either way, I ran 52/36t on my Crux, now running 50/34t and there’s no clearance issues for me. My point to the original question was about simplicity and not having to buy a bunch of new parts. If he has the parts to run his crankset, it’ll likely fit just fine without having to buy a new axle and FD.
I installed the Aldhu + P2M + Ultegra combo and I have about 2.0-2.5mm of space. A 2.5 hex wrench barely made the gap...which is tight, but I should be ok I guess:
gospastic
by gospastic
Has anyone tried a SRAM AXS1x 50T chainring? Curious to know if this would fit with non wide cranks.
fa63
by fa63
Based on how tight the clearance is on some of the photos I have seen of 48-tooth chainrings on non-wide cranks, I would say 50-tooth would be a no-go. Maybe it would work with a wide spindle.
gospastic
by gospastic
I guess only one way to find out. I have a Crux on the way and will give it a shot.
josephtroppo
by josephtroppo
So I have finally built my 2025 crux 10R, it is equipped with the new Red 13 group set.
Amazing ride; currently on Zipp 303 2019 hooked tubeless version with a 21mm inner width.
Currently on pathfinder sworks 42 which is sufficiently wide for me
Big question: will I really notice a difference and is it worth to invest in 25mm inner width wheels (ie roval terra clx)
Edit: added current tyres
Last edited by josephtroppo on Sat Dec 14, 2024 12:56 pm, edited 2 times in total.
stoney
by stoney
The Roval's might work better with 45+ sized tires.
fa63
by fa63
josephtroppo wrote:So I have finally built my 2025 crux 10R, it is equipped with the new Red 13 group set.
I wouldn't bother unless you're chasing grams (this is Weight Weenies after all Image)
req110
by req110
Hey team, what is the best option for headset bearings? Those original ones last nothing.
Sold everything, kept only gym membership and #S Crux '25 @ Force XPLR D2, Zipp 303 S XPLR
DrimeOser
by DrimeOser
Chris King Dropset for the uppper only, otherwise Wolftooth and Ceramicspeed. to me it is a suprise that such an excellent frame comes with such a garbage headset. Guess, the product manager found a way to save 2 bucks.
stanvr
by stanvr
I put in the cane creek slamset upper, has been trouble free since and the very low stack is nice if you want a low fit!
gospastic
by gospastic
I got my 2025 Crux 10R built up. Frame on my scale was 837g. Not too bad, but it's the smallest size. The included expander plug is a piece of crap! Lightweight, but fragile. I wish they included something more robust. Other than that, everything seems good. 46t is pretty tight on regular width cranks, I'm guessing I'll need to go to wide cranks to fit 50t. Weight is 7.5kg as pictured.
ill principe
by ill principe
Wow, nice build! Wish that colourway could be bought as frameset instead of the white/silver/fluo yellow option.
Current:
S-Works SL8 RTP | Diverge Comp Carbon
Retired:
S-Works SL7 | S-Works Venge | Ultimate CF SLX Mk IV | Ultimate CF SLX Mk III | S5 | R3 | Cento | ...
